跳转到主内容
How to clean sticky Canon PowerShot SX Series buttons
你所需要的
  1. How to clean sticky Canon PowerShot SX Series buttons, How to clean sticky Canon PowerShot SX Series buttons: 步骤 1 中的图像 1,1
    • The rocker buttons on a Canon superzoom camera are susceptible to debris entering the cracks. This debris travels down into the body of the camera where it can interfere with smooth operation. This guide will cover removal and cleaning of the buttons.
  2. How to clean sticky Canon PowerShot SX Series buttons: 步骤 2 中的图像 1,1
    • Remove the battery before starting.
    • Screw management is key to a successful repair. I like using a series of bowls for each side or component of the camera, with scraps of paper to document anything unusual such as an extra long screw.
    • You'll need a small cross head screwdriver, and preferably a magnet stuck to the screwdriver to assist in picking up screws.
    • Optionally a silicon grease and lubricant can be used at the last step.
  3. How to clean sticky Canon PowerShot SX Series buttons: 步骤 3 中的图像 1,2 How to clean sticky Canon PowerShot SX Series buttons: 步骤 3 中的图像 2,2
    • The camera shell opens easily enough., and all screw heads are visible. The front shell slides straight out, the sides just come off. Nothing needs to be forced, pried, or unglued.
    • The only tricky part is the back case, which has a fragile ribbon connector. Unlatch this, carefully, and slide the ribbon out.
  4. How to clean sticky Canon PowerShot SX Series buttons: 步骤 4 中的图像 1,1
    • This is your goal: disassemble the switch parts, wash them thoroughly in clean water, and dry thoroughly.
    • Optionally, use a silicon grease on the plastic and rubber parts, and a polyphenyl ether (PPE) lubricant on the gold contacts. If you don't have a PPE lubricant a very very light coating of a light lubricating oil also works. This step is optional.
结论
Now, reassemble in reverse order and try it out.
3等其他人完成本指南。
Bryce Nesbitt
于11/30/14注册
1,023 声望
创作了9篇指南
2条评论
I see 3 images but where are the instructions? what screws do I remove? where are they located? who is Bryce nesbitt anyway?
nixtur - 回复
Bryce Nesbitt is an awesome iFixit contributor. You remove every screw: as it says above they are all visible from the outside.
Bryce Nesbitt -
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 13
总计 4,345
