跳转到主内容
How to clean out a Black and Decker Toast R Oven
你所需要的
  1. How to clean out a Black and Decker Toast R Oven, How to clean out a Black and Decker Toast R Oven: 步骤 1 中的图像 1,1
    • Make sure that the toaster is unplugged before you begin.
    • Turn the toaster over with its backside face down.
    • Remove the two Phillips #4 1cm screws that attach the side panels.
  2. How to clean out a Black and Decker Toast R Oven: 步骤 2 中的图像 1,2 How to clean out a Black and Decker Toast R Oven: 步骤 2 中的图像 2,2
    • Pull downwards (towards the bottom of the unit) and outward to remove the side panels.
  3. How to clean out a Black and Decker Toast R Oven: 步骤 3 中的图像 1,1
    • Remove the metal vent piece that is below the door.
    • This should slide off easily once both of the side panels are removed.
  4. How to clean out a Black and Decker Toast R Oven: 步骤 4 中的图像 1,1
    • Remove the two Phillips #4 1 cm screws, which connect the bottom panel to the unit.
  5. How to clean out a Black and Decker Toast R Oven: 步骤 5 中的图像 1,1
    • Remove the crumb tray (the bottom, metal panel) from the toaster unit.
  6. How to clean out a Black and Decker Toast R Oven: 步骤 6 中的图像 1,1
    • Remove the aluminum strip from the bottom of unit; this is the piece that is directly under the door.
  7. How to clean out a Black and Decker Toast R Oven: 步骤 7 中的图像 1,1
    • Remove the knobs by pulling them upward; they should slide right off.
    • When placing the knobs back on the unit, make sure the semicircle notch fits correctly in the hole so that the knobs don't fall off.
  8. How to clean out a Black and Decker Toast R Oven: 步骤 8 中的图像 1,1
    • Unhook the bottom of the the display panel from the toaster unit.
    • It will be a little tough to pry off, but don't be afraid to be forceful. You can use your hands, or pliers, to bend the metal piece backwards.
  9. How to clean out a Black and Decker Toast R Oven: 步骤 9 中的图像 1,1
    • Begin to detach the back panel from the toaster unit.
    • Then, unhook the rest of the display panel.
    • This will also be a little tough to get off, but don't be afraid to be forceful.
  10. How to clean out a Black and Decker Toast R Oven: 步骤 10 中的图像 1,1
    • Finish removing the outside cover by lifting the lid upward.
  11. How to clean out a Black and Decker Toast R Oven: 步骤 11 中的图像 1,1
    • Remove the four Phillips #4 1 cm screws from the back of the unit.
  12. How to clean out a Black and Decker Toast R Oven: 步骤 12 中的图像 1,1
    • Now, you can clean the outside units of the toaster oven.
  13. How to clean out a Black and Decker Toast R Oven: 步骤 13 中的图像 1,1
    • Remove the the heating coil protection bar from the toaster unit by first pulling out the left side.
结论
4等其他人完成本指南。
Jonathan
于09/18/12注册
281 声望
创作了5篇指南
团队
Cal Poly, Team 2-10, Propen Fall 2012 Cal Poly, Team 2-10, Propen Fall 2012 的会员
CPSU-PROPEN-F12S2G10
4 名成员
创作了5篇指南
一条评论
This guide is amazing - almost equally because it is so detailed and thorough as because it helped me know exactly how to clean this almost ancient piece of equipment, that's still going strong after what must be 40+ years (in spite of not having been thoroughly, properly cleaned in probably 20!) Acknowledgement to Black & Decker of that era too - let's hear it for American-made products like this one! Thank you for creating this guide!
Lynn - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 62
总计 15,625
