跳转到主内容
How to Clean iRobot Roomba 4100 Brushes
  1. How to Clean iRobot Roomba 4100 Brushes, Battery Pack: 步骤 1 中的图像 1,1
    • Turn the Roomba upside down to be able to see the yellow battery pack.
  2. How to Clean iRobot Roomba 4100 Brushes: 步骤 2 中的图像 1,2 How to Clean iRobot Roomba 4100 Brushes: 步骤 2 中的图像 2,2
    • Remove the battery by placing your fingers into the two holes and firmly press your fingers against both sides of the battery.
    • Lift the battery directly up and out of the device.
  3. How to Clean iRobot Roomba 4100 Brushes: 步骤 3 中的图像 1,1
    • Line up the replacement battery’s larger tab side with the larger tab hole and the smaller tab side with the smaller tab hole.
    • Insert the replacement battery into the empty space and firmly press down onto the battery until two audible clicks are heard.
  4. How to Clean iRobot Roomba 4100 Brushes, Brush Guard: 步骤 4 中的图像 1,1
    • Lay the Roomba upside down on a flat surface with the blue strip away from you.
  5. How to Clean iRobot Roomba 4100 Brushes: 步骤 5 中的图像 1,2 How to Clean iRobot Roomba 4100 Brushes: 步骤 5 中的图像 2,2
    • Use your index fingers to pull the yellow tabs towards you.
    • While still pulling the yellow tabs with your index fingers, tilt up the brush guard.
    • For reassembly, make sure to push in the brush guard until it clicks into place.
  6. How to Clean iRobot Roomba 4100 Brushes: 步骤 6 中的图像 1,1
    • Pull back the brush guard to unhook it from the latches.
    • Remove the brush guard by lifting it up and out of the Roomba.
    • This picture has a change in orientation to illustrate the latches. Continue disassembling the Roomba with the blue strip away from you.
  7. How to Clean iRobot Roomba 4100 Brushes, Flexible Rubber Brush: 步骤 7 中的图像 1,1
    • Set the brush guard aside.
    • The flexible rubber brush is the smooth, all-rubber brush that is closest to the yellow battery.
  8. How to Clean iRobot Roomba 4100 Brushes: 步骤 8 中的图像 1,2 How to Clean iRobot Roomba 4100 Brushes: 步骤 8 中的图像 2,2
    • Remove the flexible rubber brush by grabbing it and pulling it up and out of the Roomba.
    • For reassembly, orient the Roomba with the battery closest to you:
    • First, insert the black end of the flexible rubber brush into the black square opening on the right side.
    • Second, lay the flexible rubber brush back into place.
  9. How to Clean iRobot Roomba 4100 Brushes, Filter: 步骤 9 中的图像 1,1
    • Lay the Roomba on a flat surface with the red side up.
  10. How to Clean iRobot Roomba 4100 Brushes: 步骤 10 中的图像 1,2 How to Clean iRobot Roomba 4100 Brushes: 步骤 10 中的图像 2,2
    • Push in the red, gumdrop-shaped button with your thumb.
    • While holding in the button, slide the back piece away from the main body of the Roomba.
  11. How to Clean iRobot Roomba 4100 Brushes: 步骤 11 中的图像 1,3 How to Clean iRobot Roomba 4100 Brushes: 步骤 11 中的图像 2,3 How to Clean iRobot Roomba 4100 Brushes: 步骤 11 中的图像 3,3
    • Flip the back piece over in your hand.
    • Using your other hand, grab the yellow tab and pull it away from the back piece.
  12. How to Clean iRobot Roomba 4100 Brushes: 步骤 12 中的图像 1,3 How to Clean iRobot Roomba 4100 Brushes: 步骤 12 中的图像 2,3 How to Clean iRobot Roomba 4100 Brushes: 步骤 12 中的图像 3,3
    • Pinch the black plastic of the filter and pull it away from the yellow filter holder.
  13. How to Clean iRobot Roomba 4100 Brushes, How to Clean iRobot Roomba 4100 Brushes: 步骤 13 中的图像 1,1
    • Remove the particle bin from the back of the Roomba.
  14. How to Clean iRobot Roomba 4100 Brushes: 步骤 14 中的图像 1,1
    • Pop out the two yellow tabs to remove the brush cover.
  15. How to Clean iRobot Roomba 4100 Brushes: 步骤 15 中的图像 1,3 How to Clean iRobot Roomba 4100 Brushes: 步骤 15 中的图像 2,3 How to Clean iRobot Roomba 4100 Brushes: 步骤 15 中的图像 3,3
    • Remove the two brushes from the iRobot Roomba 1400.
    • The brushes will easily pop in and out when cleaning them.
    • Completely remove any debris or tangled hair around the brushes when cleaning.
结论
To reassemble the iRobot Roomba 4100, follow the stated instructions in reverse order.
4等其他人完成本指南。
Scott Leonard
于10/05/10注册
445 声望
创作了3篇指南
团队
Cal Poly, Team 20-6, Maness Fall 2010 Cal Poly, Team 20-6, Maness Fall 2010 的会员
CPSU-MANESS-F10S20G6
2 名成员
创作了3篇指南
一条评论
looking for user Manual for Welch A;;yn EKG CP10
Robert Castillo - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 4,225
