跳转到主内容
How to clean and reapply thermal paste on ATI Radeon X1900 XTX
你所需要的
  1. How to clean and reapply thermal paste on ATI Radeon X1900 XTX, How to clean and reapply thermal paste on ATI Radeon X1900 XTX: 步骤 1 中的图像 1,2 How to clean and reapply thermal paste on ATI Radeon X1900 XTX, How to clean and reapply thermal paste on ATI Radeon X1900 XTX: 步骤 1 中的图像 2,2
    • Start by removing the card from the PC if you haven't already.
  2. How to clean and reapply thermal paste on ATI Radeon X1900 XTX: 步骤 2 中的图像 1,3 How to clean and reapply thermal paste on ATI Radeon X1900 XTX: 步骤 2 中的图像 2,3 How to clean and reapply thermal paste on ATI Radeon X1900 XTX: 步骤 2 中的图像 3,3
    • The fan's power cable is located towards the bottom-left of the card.
    • Disconnect the cable from the card.
    • The cable and its connector on the X1900 are fragile. Be careful, and try not to use excessive force when removing it.
  3. How to clean and reapply thermal paste on ATI Radeon X1900 XTX: 步骤 3 中的图像 1,3 How to clean and reapply thermal paste on ATI Radeon X1900 XTX: 步骤 3 中的图像 2,3 How to clean and reapply thermal paste on ATI Radeon X1900 XTX: 步骤 3 中的图像 3,3
    • Removing the heatsink from the card:
    • The clamp is held on by four small Phillips screws. Remove them, then the clamp.
    • Remove the four phillips screws surrounding the clamp.
  4. How to clean and reapply thermal paste on ATI Radeon X1900 XTX: 步骤 4 中的图像 1,1
    • Separate the heatsink and the card.
  5. How to clean and reapply thermal paste on ATI Radeon X1900 XTX: 步骤 5 中的图像 1,2 How to clean and reapply thermal paste on ATI Radeon X1900 XTX: 步骤 5 中的图像 2,2
    • Replacing Thermal Paste:
    • Using a Q-tip/cotton swab and rubbing alcohol, clean the copper plate that protrudes from the bottom of the heatsink.
  6. How to clean and reapply thermal paste on ATI Radeon X1900 XTX: 步骤 6 中的图像 1,2 How to clean and reapply thermal paste on ATI Radeon X1900 XTX: 步骤 6 中的图像 2,2
    • Removing the heatsink's plastic cover:
    • Remove these Phillips screws.
    • Seperate the plastic cover from the metal heat sink.
  7. How to clean and reapply thermal paste on ATI Radeon X1900 XTX: 步骤 7 中的图像 1,2 How to clean and reapply thermal paste on ATI Radeon X1900 XTX: 步骤 7 中的图像 2,2
    • Cleaning dust out of the heat sink:
    • Using a cotton swab/q-tip, clean the edges of the heat sink. You can also use canned air if available.
  8. How to clean and reapply thermal paste on ATI Radeon X1900 XTX: 步骤 8 中的图像 1,2 How to clean and reapply thermal paste on ATI Radeon X1900 XTX: 步骤 8 中的图像 2,2
    • Using the same method that you used to clean the copper plate, clean the surface of the GPU die.
  9. How to clean and reapply thermal paste on ATI Radeon X1900 XTX: 步骤 9 中的图像 1,3 How to clean and reapply thermal paste on ATI Radeon X1900 XTX: 步骤 9 中的图像 2,3 How to clean and reapply thermal paste on ATI Radeon X1900 XTX: 步骤 9 中的图像 3,3
    • Re-Applying Thermal Paste:
    • Apply a small glob of thermal paste to the corner of the die, (I recommend using Arctic Silver 5) and use an index card to spread a thin, even layer of it over the surface of the chip.
    • For more detailed directions, follow our Applying Thermal Paste Guide.
结论
13等其他人完成本指南。
Chris Green
于10/11/09注册
36,978 声望
创作了49篇指南
团队
Master Techs Master Techs 的会员
Community
322 名成员
创作了2,519篇指南
一条评论
Super!!!!! j'ai suivi a la lettre; j'espère sauver ma carte; j'attends la pate thermique.
guz - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 11
总计 13,270
