跳转到主内容
How to clean and maintain your Vape Mod
你所需要的
  1. How to clean and maintain your Vape Mod, How to clean and maintain your Vape Mod: 步骤 1 中的图像 1,3 How to clean and maintain your Vape Mod, How to clean and maintain your Vape Mod: 步骤 1 中的图像 2,3 How to clean and maintain your Vape Mod, How to clean and maintain your Vape Mod: 步骤 1 中的图像 3,3
    • Although maintenance for your Vape Mod shouldn't be dangerous, it can be messy. It is recommended to do this on top of a paper towel.
    • Start by removing the top cap of your Vape Mod.
  2. How to clean and maintain your Vape Mod: 步骤 2 中的图像 1,3 How to clean and maintain your Vape Mod: 步骤 2 中的图像 2,3 How to clean and maintain your Vape Mod: 步骤 2 中的图像 3,3
    • Unscrew RDA (rebuildable dripping atomizer) and take it off.
  3. How to clean and maintain your Vape Mod: 步骤 3 中的图像 1,3 How to clean and maintain your Vape Mod: 步骤 3 中的图像 2,3 How to clean and maintain your Vape Mod: 步骤 3 中的图像 3,3
    • Many Vape Mods are different, you might have to take out your battery in a different way than shown.
    • At the bottom of the tube, unscrew the firing pin.
    • Take the battery out of the Vape Mod.
  4. How to clean and maintain your Vape Mod: 步骤 4 中的图像 1,3 How to clean and maintain your Vape Mod: 步骤 4 中的图像 2,3 How to clean and maintain your Vape Mod: 步骤 4 中的图像 3,3
    • Inspect all of the parts that will need to be cleaned:
    • The firing pin
    • The RDA threading
    • The bottom of the inside of the tube
  5. How to clean and maintain your Vape Mod: 步骤 5 中的图像 1,2 How to clean and maintain your Vape Mod: 步骤 5 中的图像 2,2
    • Clean the Firing pin by dipping a paper towel into hot water.
    • Carefully rotate the hot towel around the middle area, rubbing the grime away.
  6. How to clean and maintain your Vape Mod: 步骤 6 中的图像 1,3 How to clean and maintain your Vape Mod: 步骤 6 中的图像 2,3 How to clean and maintain your Vape Mod: 步骤 6 中的图像 3,3
    • Get a new paper towel wet with the hot water.
    • Clean the RDA threading by rotating the wet paper towel back and forth across it.
  7. How to clean and maintain your Vape Mod: 步骤 7 中的图像 1,3 How to clean and maintain your Vape Mod: 步骤 7 中的图像 2,3 How to clean and maintain your Vape Mod: 步骤 7 中的图像 3,3
    • Twist it until it can easily fit inside of the tube.
    • Use your finger or another long tool to rotate the paper towel along the sides and the bottom of the tube.
  8. How to clean and maintain your Vape Mod: 步骤 8 中的图像 1,3 How to clean and maintain your Vape Mod: 步骤 8 中的图像 2,3 How to clean and maintain your Vape Mod: 步骤 8 中的图像 3,3
    • Put your Vape Mod back together by doing steps 1 - 2 in reverse. (Leave the mouthpiece of the top cap off).
    • Careful, firing your Vape Mod produces heat and can make the device HOT!
    • Fire your Vape Mod. If the coils are heating up, it has been fixed!
结论
If your Vape Mod is still not firing, consider getting a new build.
13等其他人完成本指南。
Jessie Smith
于09/29/15注册
677 声望
撰写一个指南
团队
Cal Poly, Team 14-3, Green Fall 2015 Cal Poly, Team 14-3, Green Fall 2015 的会员
CPSU-GREEN-F15S14G3
4 名成员
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 11
过去 30 天: 34
总计 11,277
