跳转到主内容
How to clean a water damaged Nexus 5 Display
你所需要的
    • I'm starting this guide with the front frame and LCD display, to do this you must complete all the steps on the Nexus 5 Teardown guide Nexus 5 Teardown
    • In this video you can see the damage; the screen has lost touch sensitivity in the areas that are blank in this drawing program.
  1. How to clean a water damaged Nexus 5 Display, Separate the screen and the frame.: 步骤 2 中的图像 1,2 How to clean a water damaged Nexus 5 Display, Separate the screen and the frame.: 步骤 2 中的图像 2,2
    在这个步骤中使用的工具:
    Heat Gun
    $24.99
    购买
    • Flex what needs to be unstick
    • The flex is strongly stuck on the frame, to remove it warm with a Heat Gun.
    I don't really understand this part :/
    pawzubr - 回复
    Hi, to separate the screen and the frame you need unstick the flex.
    This flex is strongly sticked on the frame and if you tried to unstick you might damage it, you can separate easily if you apply some heat on it.
    Once you have applied heat on the flex you can pull it and this will unstick easily and then you can continue with the next step.
    Eneider Colina -
  2. How to clean a water damaged Nexus 5 Display, Heating the screen at 50°C.: 步骤 3 中的图像 1,2 How to clean a water damaged Nexus 5 Display, Heating the screen at 50°C.: 步骤 3 中的图像 2,2
    • I used a multimeter with temperature measurement; it's not exact but it works.
    • Heating the edges.
  3. How to clean a water damaged Nexus 5 Display, Separating the screen and the frame.: 步骤 4 中的图像 1,3 How to clean a water damaged Nexus 5 Display, Separating the screen and the frame.: 步骤 4 中的图像 2,3 How to clean a water damaged Nexus 5 Display, Separating the screen and the frame.: 步骤 4 中的图像 3,3
    • Be careful with the flex!
    • If you are installing a new LCD screen you must put it on the frame and follow all the steps in reverse order.
    • With a guitar pick you can separate the screen slowly.
  4. How to clean a water damaged Nexus 5 Display, Removing the layers on the screen.: 步骤 5 中的图像 1,3 How to clean a water damaged Nexus 5 Display, Removing the layers on the screen.: 步骤 5 中的图像 2,3 How to clean a water damaged Nexus 5 Display, Removing the layers on the screen.: 步骤 5 中的图像 3,3
    • I used a hair dryer with cold air to help to separate the layers.
    • The first layer we need remove.
    • The second layer still on the frame of the screen.
    • The wet layers are on the screen
  5. How to clean a water damaged Nexus 5 Display, Removing the layers on the screen pt2: 步骤 6 中的图像 1,3 How to clean a water damaged Nexus 5 Display, Removing the layers on the screen pt2: 步骤 6 中的图像 2,3 How to clean a water damaged Nexus 5 Display, Removing the layers on the screen pt2: 步骤 6 中的图像 3,3
    • use the guitar pick to separate the layers
    • 2nd layer
    • 3rd layer
    shall i remove first two layers???? AND when reassembling the phone - i should reassemble them too??? or i can trash them?
    aranofski - 回复
  6. How to clean a water damaged Nexus 5 Display, Dry and clean.: 步骤 7 中的图像 1,3 How to clean a water damaged Nexus 5 Display, Dry and clean.: 步骤 7 中的图像 2,3 How to clean a water damaged Nexus 5 Display, Dry and clean.: 步骤 7 中的图像 3,3
    • 3rd layer - don't separate.
    • 4th layer - don't separate.
    • 5th layer don't remove.
    • You can dry and clean all the layers (i use electrical contact cleaner).
  7. How to clean a water damaged Nexus 5 Display, Reassembling the layers.: 步骤 8 中的图像 1,1
    • I cleaned all the layers perfectly with electronic contact cleaner.
    • Once you have cleaned and dried the layers you must reassemble in reverse order.
    • I'm very scared disassembling the layers of the screen, i thought it wouldn't work but despite everything worked.
    • I did this because i can't use the phone, the screen are marked by itself.
    • This screen is bad but it works almost perfectly as you can see on the video.
    • I must replace the LCD screen, but if you haven't money to replace and you want use which you have, this guide is perfect for you.
    Did it also fix the touchscreen not responding? Because a heve the exact same problem even the same place where the touch isn't working. Thanks in advance
    Stijn Liekens - 回复
    Hi sorry for answer late; no, this not fix the touchscreen, i still have the trouble, the touchscreen on that side of the screen is damaged and the only solution is replace it with a new screen, but if you screen its crazy and it your mark by that itself, is able to fix and avoid any inconvenience this causes.
    Eneider Colina -
结论
19等其他人完成本指南。
Eneider Colina
于09/20/13注册
2,362 声望
创作了9篇指南
团队
Comunidad para traductores de español Comunidad para traductores de español 的会员
Community
22 名成员
创作了187篇指南
2条评论
Hello, I dropped my Nexus 5 today and the front glass got broken; the LCD and the touch are working perfectly. Is it possible to only replace the front glass? Thanks
Mohamed Annous - 回复
Hello there. My Lg Nexus5-D821 phone just went blackout, that is had a dark screen when it was charging.nothing is showing on the screen even if you try to switch it on its failing to show anything on the screen. Someone looking at it is failing to diagnose its problem. He tested the battery on another phone is charging. What should I do to fix it. Kindly assist.
Beatrice - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 67,653
