跳转到主内容
How to clean a rusting Microwave
你所需要的
  1. How to clean a rusting Microwave, Prepare the surface: 步骤 1 中的图像 1,1
    • Unplug the microwave oven.
    • Clean the surface of all grease residue with alcohol or acetone.
  2. How to clean a rusting Microwave, Remove the rust: 步骤 2 中的图像 1,1
    • Remove the glass tray and roller ring
    • Remove the stuck rust with steel wool.
    • Wipe away any debris with a dry cloth
  3. How to clean a rusting Microwave, Apply the paint: 步骤 3 中的图像 1,1
    • Shake the tin
    • Apply a thin coat with the brush
    • Give the paint at least 6 hours to dry
    • Apply 1 or 2 more coats as appriopriate
  4. How to clean a rusting Microwave, Replace tray: 步骤 4 中的图像 1,1
    • Allow time for the paint coatings to dry properly, ideally overnight with the door open.
    • Replace roller ring and tray. Plug your oven to the power outlet.
    • You are now ready to use your microwave oven again!
终点
21等其他人完成本指南。
Tristan Hill
于08/31/15注册
600 声望
撰写一个指南
4指南评论
Thanks so much!!! I got a small microwave from a rental unit ( it was rusted ans I thought i would be excellent for my fishing cabin ( in the wine country ). I WANTED TO USE EPOXY OR ENGINE PAINT!!! The mention set so many individuals at multiple sites off to saying things about toxic fumes and other ridiculous things. there’s even a special paint Amazon sells!!! https://www.google.com/search?client=fir...
wgcormier - 回复
Thank you for the information.
Marci B Jeffcoats - 回复
Where do I buy the special paint
Diane Sauchuk - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 24
过去 30 天: 140
总计 63,575
