跳转到主内容
How to clean Non-functoning buttons on remote
你所需要的
  1. How to clean Non-functoning buttons on remote, How to clean Non-functoning buttons on remote: 步骤 1 中的图像 1,1
    • For later testing: X marks butttons which still work, O marks buttons that don't.
  2. How to clean Non-functoning buttons on remote: 步骤 2 中的图像 1,2 How to clean Non-functoning buttons on remote: 步骤 2 中的图像 2,2
    • Open battery housing and remove the batteries
    • Remove the screw located in the center of the battery housing
  3. How to clean Non-functoning buttons on remote: 步骤 3 中的图像 1,1
    • Top and bottom shell of the remote are held together by 4 latches per side. The most fore and aft ones are located about 1cm from each end
    • Pry them open with a small flat head. If you're carefull that will leave only tiny scratches, but it does take some force
  4. How to clean Non-functoning buttons on remote: 步骤 4 中的图像 1,2 How to clean Non-functoning buttons on remote: 步骤 4 中的图像 2,2
    • Once open, remove the insides and clean them from all the drinks and what not that has been poored over the remote
    • If necessary, add contact spray or alike to the buttom of the rubber buttons
  5. How to clean Non-functoning buttons on remote: 步骤 5 中的图像 1,1
    • After cleaning and before full re-assembly, you might want to try if things improved.
    • Put the cicruit board back in, add batteries and put the rubber mats onto the circuit board
    • If the repair worked, you should the red top LED flashing
    • Put it all back together again. (Don't forget the screw in the battery housing.)
    • You might need some new batteries as well
结论
23等其他人完成本指南。
andre
于03/12/12注册
1,800 声望
创作了4篇指南
29指南评论
Having trouble with the latches. Can you explain the technique you used to pry them open?
Thanks!
bob - 回复
Hi Bob. Force, brute force. Sorry, I don't have a better advice for you. ;-)
andre -
thanks, I fixed mine using your guide.
surfer - 回复
You are a life saver, just fixed my onkyo RC-737m control with this guide... Broken a plastic clip but can't tell when it's back together. Cheers again! Leon
Leon Parsons - 回复
Géniaaaaaaaaaaal!
Deux télécommandes dont les boutons du volume ne répondaient plus! Et hop c'est revenu ;-)
Merciiiiiiii
Thierry Paulet - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 15
过去 30 天: 140
总计 38,846
