跳转到主内容
How to clean Nokia 3120
你所需要的
  1. How to clean Nokia 3120, Battery Installation: 步骤 1 中的图像 1,3 How to clean Nokia 3120, Battery Installation: 步骤 1 中的图像 2,3 How to clean Nokia 3120, Battery Installation: 步骤 1 中的图像 3,3
    • Remove the back cover plate of the phone. To do this press down the lock as you slide the cover toward the bottom of the phone.
  2. How to clean Nokia 3120: 步骤 2 中的图像 1,1
    • Once the back cover plate is removed, the battery should be exposed. Remove the battery by prying it out. This can be done with your finger-nail or a prying tool.
  3. How to clean Nokia 3120, Face Plate: 步骤 3 中的图像 1,3 How to clean Nokia 3120, Face Plate: 步骤 3 中的图像 2,3 How to clean Nokia 3120, Face Plate: 步骤 3 中的图像 3,3
    • Using your fingernails or another tool, pry the front face plate out along its edges and corners.
  4. How to clean Nokia 3120, How to clean Nokia 3120: 步骤 4 中的图像 1,1
    • If dirt has gotten inside the phone, both the lens and the case should be cleaned.
    • Once the screen is exposed, spray cleaning solution onto a soft cloth and wipe the screen.
    • Make sure to thoroughly dry the screen.
  5. How to clean Nokia 3120: 步骤 5 中的图像 1,1
    • Repeat the cleaning process on the clear plastic connected to the face-plate.
    • If the screen still appears dirty after a thorough cleaning, parts may have to be replaced. See the troubleshooting guide.
结论
2等其他人完成本指南。
团队
Clemson, Team 13-2, Benson Spring 2013 Clemson, Team 13-2, Benson Spring 2013 的会员
CLEM-BENSON-S13S13G2
3 名成员
创作了14篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 13
总计 1,099
