跳转到主内容
How to clean Motorola T720c screen and LCD
你所需要的
  1. How to clean Motorola T720c screen and LCD, How to clean Motorola T720c screen and LCD: 步骤 1 中的图像 1,1
    • On the door's bottom edge, locate the gap between the external and internal screen covers.
    • Using a spudger (not shown), gently pry apart the external and internal covers until the sides start to separate.
    • Continue working your way along the edges of the phone, alternating sides, until the external cover can be easily removed.
  2. How to clean Motorola T720c screen and LCD: 步骤 2 中的图像 1,2 How to clean Motorola T720c screen and LCD: 步骤 2 中的图像 2,2
    • On the display housing, locate and unscrew the four corner T6 Torx screws connecting the housing and the internal cover.
  3. How to clean Motorola T720c screen and LCD: 步骤 3 中的图像 1,2 How to clean Motorola T720c screen and LCD: 步骤 3 中的图像 2,2
    • The fragile wire strip connecting the display housing to the circuit board is located on the left side of the inner hinge.
    • Locate the gap between the display housing and internal cover, in the same manner you would flip open the phone, use your finger (not shown) to lift the housing from the cover and set it down.
  4. How to clean Motorola T720c screen and LCD: 步骤 4 中的图像 1,1
    • Using a lens cloth, wipe away any dust or debris from the display or screens.
结论
Amy
于10/15/12注册
1 声望
创作了4篇指南
团队
University of Maine, Team 1-4, Diaz Fall 2012 University of Maine, Team 1-4, Diaz Fall 2012 的会员
UMAINE-DIAZ-F12S1G4
5 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 466
