跳转到主内容
How to clean Microtek ScanMaker 5900 glass
你所需要的
  1. How to clean Microtek ScanMaker 5900 glass, Remove serial port connection: 步骤 1 中的图像 1,3 How to clean Microtek ScanMaker 5900 glass, Remove serial port connection: 步骤 1 中的图像 2,3 How to clean Microtek ScanMaker 5900 glass, Remove serial port connection: 步骤 1 中的图像 3,3
    • Loosen the screws on the serial port by turning them counter clockwise by hand.
    • After loosening the screws, pull the serial port out.
  2. How to clean Microtek ScanMaker 5900 glass, Remove Lid: 步骤 2 中的图像 1,3 How to clean Microtek ScanMaker 5900 glass, Remove Lid: 步骤 2 中的图像 2,3 How to clean Microtek ScanMaker 5900 glass, Remove Lid: 步骤 2 中的图像 3,3
    • Lift lid to its vertical position.
    • Pull lid straight up to remove it from the scanner.
  3. How to clean Microtek ScanMaker 5900 glass, Detach plastic latches: 步骤 3 中的图像 1,3 How to clean Microtek ScanMaker 5900 glass, Detach plastic latches: 步骤 3 中的图像 2,3 How to clean Microtek ScanMaker 5900 glass, Detach plastic latches: 步骤 3 中的图像 3,3
    • Push the plastic opening tools into the crack between the top and the bottom of the chassis.
  4. How to clean Microtek ScanMaker 5900 glass, Continue latch detachment: 步骤 4 中的图像 1,3 How to clean Microtek ScanMaker 5900 glass, Continue latch detachment: 步骤 4 中的图像 2,3 How to clean Microtek ScanMaker 5900 glass, Continue latch detachment: 步骤 4 中的图像 3,3
    • After placing one plastic opening tool into the slit, slide other plastic opening tools along the slit to detach the top from the bottom of the chassis.
    • Go all the way along the chassis until you can lift the upper lid.
  5. How to clean Microtek ScanMaker 5900 glass, Fully remove the upper lid: 步骤 5 中的图像 1,3 How to clean Microtek ScanMaker 5900 glass, Fully remove the upper lid: 步骤 5 中的图像 2,3 How to clean Microtek ScanMaker 5900 glass, Fully remove the upper lid: 步骤 5 中的图像 3,3
    • Do not fully remove the lid until you remove the ribbon cable attached to the front of the upper lid.
    • Do this by grabbing the upper lid from the sides and rotating it ninety degrees so it is perpendicular to the bottom lid.
    • Grab the ribbon cable and gently pull it out of its slot with your fingers.
    • The upper lid can now safely be removed from the bottom lid.
  6. How to clean Microtek ScanMaker 5900 glass, How to clean Microtek ScanMaker 5900 glass: 步骤 6 中的图像 1,1
    • Using a soft lint-free cloth clean the surface glass of dust, finger prints and other debris.
结论
团队
Cal Poly, Team 6-9, Regan Fall 2011 Cal Poly, Team 6-9, Regan Fall 2011 的会员
CPSU-REGAN-F11S6G9
2 名成员
创作了22篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 2,705
