跳转到主内容
How to clean Magnavox MWD200F gears
你所需要的
  1. How to clean Magnavox MWD200F gears, Faceplate: 步骤 1 中的图像 1,1
    • Use a Phillips #2 screwdriver to remove the two screws on the top of the device toward the back.
  2. How to clean Magnavox MWD200F gears: 步骤 2 中的图像 1,1
    • Remove the plastic cover by lifting up the back and pulling it away from the faceplate.
  3. How to clean Magnavox MWD200F gears: 步骤 3 中的图像 1,1
    • Unclip the three latches on the bottom of the device.
  4. How to clean Magnavox MWD200F gears: 步骤 4 中的图像 1,1
    • Pull the faceplate off.
  5. How to clean Magnavox MWD200F gears, Disk Drive: 步骤 5 中的图像 1,2 How to clean Magnavox MWD200F gears, Disk Drive: 步骤 5 中的图像 2,2
    • Use a Phillips #2 screwdriver to remove the two screws at the base of the disk drive.
  6. How to clean Magnavox MWD200F gears: 步骤 6 中的图像 1,2 How to clean Magnavox MWD200F gears: 步骤 6 中的图像 2,2
    • Use the screwdriver to remove two screws on either side of the silver security bar.
  7. How to clean Magnavox MWD200F gears: 步骤 7 中的图像 1,2 How to clean Magnavox MWD200F gears: 步骤 7 中的图像 2,2
    • Pull out the silver security bar and set aside.
  8. How to clean Magnavox MWD200F gears: 步骤 8 中的图像 1,1
    • Take out the two screws on either side of the green circuit board.
  9. How to clean Magnavox MWD200F gears: 步骤 9 中的图像 1,2 How to clean Magnavox MWD200F gears: 步骤 9 中的图像 2,2
    • Carefully lift the board just enough to remove the disk drive.
  10. How to clean Magnavox MWD200F gears: 步骤 10 中的图像 1,3 How to clean Magnavox MWD200F gears: 步骤 10 中的图像 2,3 How to clean Magnavox MWD200F gears: 步骤 10 中的图像 3,3
    • Remove the two screws at the back of the disk drive.
  11. How to clean Magnavox MWD200F gears: 步骤 11 中的图像 1,2 How to clean Magnavox MWD200F gears: 步骤 11 中的图像 2,2
    • Gently lift the disk drive out of the DVD player.
    • The disk drive is still attached but you are now able to get to underneath it for cleaning and maintenance.
  12. How to clean Magnavox MWD200F gears, How to clean Magnavox MWD200F gears: 步骤 12 中的图像 1,2 How to clean Magnavox MWD200F gears, How to clean Magnavox MWD200F gears: 步骤 12 中的图像 2,2
    • Turn disc drive over so you can see the gears on the bottom.
  13. How to clean Magnavox MWD200F gears: 步骤 13 中的图像 1,2 How to clean Magnavox MWD200F gears: 步骤 13 中的图像 2,2
    • Using a cotton swap or a cleansing cloth and alcohol, gently rub the gears ridding of any debris and dust.
    • You can also use a compressed air can as well. Just point the nozzle at the gears and spray with the compressed air.
结论
2等其他人完成本指南。
Taryn
于09/15/11注册
109 声望
创作了4篇指南
团队
University of Maine, Team 1-2, Diaz Fall 2011 University of Maine, Team 1-2, Diaz Fall 2011 的会员
UMAINE-DIAZ-F11S1G2
2 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 818
