当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Unscrew a total of 6 4.45 mm phillips head screws using a #00 phillips head screwdriver.
There are 2 screws on the left side (when looking at the front of the camera).
There are 3 screws on the bottom
There is 1 screw on the right side
Turn to the bottom of the camera.
Open the memory card cover by sliding the "CARD/BATT." button up, and then pulling the cover to the left.
Start from the battery compartment and remove the back cover.
Caution: Do not tug on the back cover after it is removed. This could tear the ribbon attaching the back cover to the camera body.
Remove the connecting ribbon from the body of the camera using a pair of tweezers.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
