跳转到主内容
How to clean Apple Mighty Mouse scroll ball
你所需要的
  1. How to clean Apple Mighty Mouse scroll ball, How to clean Apple Mighty Mouse scroll ball: 步骤 1 中的图像 1,1
    • Before you continue, turn off the mouse using the slide switch underneath the mouse.
    • Before disassembling the mouse, first try scrubbing the mouse ball with a toothbrush and isopropyl alcohol. Be sure to get the bristles between the ball and the housing as this will help remove dirt and dust that is clogging the rollers inside.
    • You can also try blowing into the "ball hole" with a can of compressed air.
结论
Allow the mouse to dry for a few minutes before turning it back on to test it.
52等其他人完成本指南。
bushing
于04/23/10注册
10,463 声望
创作了13篇指南
15指南评论
In order to clean perfectly the scrollball, you can hold the mouse upside down, and roll very quickly the scrollball on a white A4 papersheet (As if you wanted to colour the papersheet with the scrollball). Normally, you'll see some grey stripe of dust on the paper sheet!
Ludal - 回复
Wow - Ludal's advice actually worked! I'm amazed. Paper -- just a plain sheet of paper.
Marvin Miller -
I can't believe I just found this post in 2015, gotta say thank you for saving $53 bucks!
Junior Harrison -
I actually did both things but I used one of those wipes for eyeglasses which have alcohol in them after rubbing it on paper. Worked great.
Brian Kemian -
Thanks a loit. Even in 2020 it helped ;-)
Robert Reichel -
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 31
过去 30 天: 138
总计 45,935
