跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
This guide applies to later style turbo diesel engines that have a translucent plastic overflow tank for observing coolant level.
  1. Checking coolant level is simple of the turbo diesel cars because of the translucent overflow tank.
    • Checking coolant level is simple of the turbo diesel cars because of the translucent overflow tank.
    • Find the tank, it will be on the passenger's side under the hood forward of the battery.
  2. 任天堂 Switch 套装
    A quick fix to get back in the game
    Shop Switch Kits
    任天堂 Switch 套装
    Shop Switch Kits
  3. Now get down low and have a look at the front of the tank.
    • Now get down low and have a look at the front of the tank.
    • Note the arrow that points to a line at about the mid-point of the tank. This is the level the coolant should be at.
  4. If your coolant is low, top it off with a mix of about 50/50 distilled water to coolant. Only use a proper coolant for these cars, either the Genuine Mercedes coolant or one that is specified and formulated for the application.
    • If your coolant is low, top it off with a mix of about 50/50 distilled water to coolant. Only use a proper coolant for these cars, either the Genuine Mercedes coolant or one that is specified and formulated for the application.
结论
If your coolant is low, top it off only when the engine is cool!
Nicolas Siemsen
于2013年12月06日注册
32,512 信誉积分
创作了79篇指南
团队
Master Techs Master Techs 的会员
Community
292 名成员
创作了835篇指南
It's also a good idea to check the color of the coolant. Very dark or sooty coolant may indicate engine oil is getting mixed into the coolant due to a blown head gasket, or more seriously, cracks in the engine block.
Noshtzy - 回复
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 4
过去的30天: 25
总计 3,190
