跳转到主内容
How to check or clean Samsung DVD-P230 buttons
你所需要的
  1. How to check or clean Samsung DVD-P230 buttons, Outer Cover & Faceplate: 步骤 1 中的图像 1,3 How to check or clean Samsung DVD-P230 buttons, Outer Cover & Faceplate: 步骤 1 中的图像 2,3 How to check or clean Samsung DVD-P230 buttons, Outer Cover & Faceplate: 步骤 1 中的图像 3,3
    • Open the tray by pressing the eject button
    • Remove the DVD tray faceplate by pushing the faceplate up off of the tray.
  2. How to check or clean Samsung DVD-P230 buttons: 步骤 2 中的图像 1,1
    • Press the eject button to insert the tray
    • After the tray is closed unplug DVD player
  3. How to check or clean Samsung DVD-P230 buttons: 步骤 3 中的图像 1,1
    • Unscrew the 3 screws in the back.
  4. How to check or clean Samsung DVD-P230 buttons: 步骤 4 中的图像 1,2 How to check or clean Samsung DVD-P230 buttons: 步骤 4 中的图像 2,2
    • Pull the outer case upward and then towards you.
  5. How to check or clean Samsung DVD-P230 buttons: 步骤 5 中的图像 1,3 How to check or clean Samsung DVD-P230 buttons: 步骤 5 中的图像 2,3 How to check or clean Samsung DVD-P230 buttons: 步骤 5 中的图像 3,3
    • There are six symmetrically placed tabs holding in the front faceplate. Unhook these six tabs to loosen the faceplate.
  6. How to check or clean Samsung DVD-P230 buttons: 步骤 6 中的图像 1,2 How to check or clean Samsung DVD-P230 buttons: 步骤 6 中的图像 2,2
    • Pull off front faceplate. This may take a couple of tries to get all six tabs unhooked simultaneously.
  7. How to check or clean Samsung DVD-P230 buttons, Power Cord: 步骤 7 中的图像 1,3 How to check or clean Samsung DVD-P230 buttons, Power Cord: 步骤 7 中的图像 2,3 How to check or clean Samsung DVD-P230 buttons, Power Cord: 步骤 7 中的图像 3,3
    • Locate the white clip that attaches the cord to the motherboard
    • Grasp clip and squeeze to release
    • Lift up and remove power cord
    • Slide cord mount from outer case
  8. How to check or clean Samsung DVD-P230 buttons, Tray: 步骤 8 中的图像 1,3 How to check or clean Samsung DVD-P230 buttons, Tray: 步骤 8 中的图像 2,3 How to check or clean Samsung DVD-P230 buttons, Tray: 步骤 8 中的图像 3,3
    • Remove the three screws holding in the DVD tray
  9. How to check or clean Samsung DVD-P230 buttons: 步骤 9 中的图像 1,2 How to check or clean Samsung DVD-P230 buttons: 步骤 9 中的图像 2,2
    • Remove the power cord and first two ribbons by pulling them directly out of their sockets.
  10. How to check or clean Samsung DVD-P230 buttons: 步骤 10 中的图像 1,2 How to check or clean Samsung DVD-P230 buttons: 步骤 10 中的图像 2,2
    • Gently lift the DVD tray off of the motherboard.
  11. How to check or clean Samsung DVD-P230 buttons, How to check or clean Samsung DVD-P230 buttons: 步骤 11 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Use the tweezers to make sure all the buttons aren't stuck.
结论
3等其他人完成本指南。
Mitchell Hart
于01/21/11注册
903 声望
创作了5篇指南
团队
Cal Poly, Team 3-30, Regan Winter 2011 Cal Poly, Team 3-30, Regan Winter 2011 的会员
CPSU-REGAN-W11S3G30
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 1,504
