跳转到主内容
How to check Sony Ericsson W200i battery voltage
你所需要的
  1. How to check Sony Ericsson W200i battery voltage, Disassembling Sony Ericsson W200i Battery: 步骤 1 中的图像 1,2 How to check Sony Ericsson W200i battery voltage, Disassembling Sony Ericsson W200i Battery: 步骤 1 中的图像 2,2
    • Slide the battery cover up and off the phone.
  2. How to check Sony Ericsson W200i battery voltage: 步骤 2 中的图像 1,2 How to check Sony Ericsson W200i battery voltage: 步骤 2 中的图像 2,2
    • Pop the battery out of its slot by lifting it up.
  3. How to check Sony Ericsson W200i battery voltage, How to check Sony Ericsson W200i battery voltage: 步骤 3 中的图像 1,2 How to check Sony Ericsson W200i battery voltage, How to check Sony Ericsson W200i battery voltage: 步骤 3 中的图像 2,2
    • Plug the red probe into the center jack, the black probe into the bottom jack, and turn the range selector switch to 20 DCV.
    • Turn the multimeter on.
  4. How to check Sony Ericsson W200i battery voltage: 步骤 4 中的图像 1,1
    • Touch the red probe to the indicated positive side and the black probe to the indicated negative side.
    • Replace the battery if the voltage reads below 2.5 volts.
结论
2等其他人完成本指南。
Ryan Waltman
于01/14/11注册
111 声望
撰写一个指南
团队
Cal Poly, Team 14-10, Forte Winter 2011 Cal Poly, Team 14-10, Forte Winter 2011 的会员
CPSU-FORTE-W11S14G10
5 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 8
总计 5,369
