简介
Checking the battery is fairly easy, all you will need is a multimeter, which can be purchased at a local hardware store.
  1. Slide the battery cover up and off the phone.
    • Slide the battery cover up and off the phone.
  2. Pop the battery out of its slot by lifting it up.
    • Pop the battery out of its slot by lifting it up.
    • Plug the red probe into the center jack, the black probe into the bottom jack, and turn the range selector switch to 20 DCV.
      • Turn the multimeter on.
    • Touch the red probe to the indicated positive side and the black probe to the indicated negative side.
      • Replace the battery if the voltage reads below 2.5 volts.
结论
Ryan Waltman
于2011年01月14日注册
111 信誉积分
撰写一个指南
团队
Cal Poly, Team 14-10, Forte Winter 2011 Cal Poly, Team 14-10, Forte Winter 2011 的会员
CPSU-FORTE-W11S14G10
5 名成员
创作了16篇指南
浏览统计数据:
过去的24小时: 0
过去的7天: 2
过去的30天: 6
总计 4,894
