跳转到主内容
How to check Magnavox MWD200F fuses
你所需要的
  1. How to check Magnavox MWD200F fuses, Faceplate: 步骤 1 中的图像 1,1
    • Use a Phillips #2 screwdriver to remove the two screws on the top of the device toward the back.
  2. How to check Magnavox MWD200F fuses: 步骤 2 中的图像 1,1
    • Remove the plastic cover by lifting up the back and pulling it away from the faceplate.
  3. How to check Magnavox MWD200F fuses: 步骤 3 中的图像 1,1
    • Unclip the three latches on the bottom of the device.
  4. How to check Magnavox MWD200F fuses: 步骤 4 中的图像 1,1
    • Pull the faceplate off.
  5. How to check Magnavox MWD200F fuses, How to check Magnavox MWD200F fuses: 步骤 5 中的图像 1,1
    • Now that the device is open, you can check for any blown fuses that may need to be replaced.
结论
另外一个人完成了本指南。
Taryn
于09/15/11注册
109 声望
创作了4篇指南
团队
University of Maine, Team 1-2, Diaz Fall 2011 University of Maine, Team 1-2, Diaz Fall 2011 的会员
UMAINE-DIAZ-F11S1G2
2 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 998
