跳转到主内容
How to check Fujifilm FinePix S8200 for loose LCD connection
你所需要的
  1. How to check Fujifilm FinePix S8200 for loose LCD connection, Batteries: 步骤 1 中的图像 1,1
    • Turn the camera upside down so you can access the battery chamber.
    • Make sure that the camera is powered off before opening the battery chamber. Not doing so could damage your memory card.
  2. How to check Fujifilm FinePix S8200 for loose LCD connection: 步骤 2 中的图像 1,1
    • Push the battery chamber latch in the direction of the front of the camera. Keeping tension on the latch, slide the battery chamber cover toward the outside of the camera, opening the battery chamber.
  3. How to check Fujifilm FinePix S8200 for loose LCD connection: 步骤 3 中的图像 1,1
    • With the battery chamber open, remove the old batteries.
    • When replacing the batteries, remember that the battery orientation is shown by the + and - marks. Each mark indicates which side of the battery faces up in the chamber.
  4. How to check Fujifilm FinePix S8200 for loose LCD connection, Rear Housing Cover: 步骤 4 中的图像 1,3 How to check Fujifilm FinePix S8200 for loose LCD connection, Rear Housing Cover: 步骤 4 中的图像 2,3 How to check Fujifilm FinePix S8200 for loose LCD connection, Rear Housing Cover: 步骤 4 中的图像 3,3
    • Remove the 4mm JIS #00 screws from the sides and bottom of the camera.
  5. How to check Fujifilm FinePix S8200 for loose LCD connection: 步骤 5 中的图像 1,3 How to check Fujifilm FinePix S8200 for loose LCD connection: 步骤 5 中的图像 2,3 How to check Fujifilm FinePix S8200 for loose LCD connection: 步骤 5 中的图像 3,3
    • Carefully pry away the rear housing cover with the plastic opening tool.
  6. How to check Fujifilm FinePix S8200 for loose LCD connection: 步骤 6 中的图像 1,1
    • Remove the rear housing cover by carefully pulling it away from the camera.
  7. How to check Fujifilm FinePix S8200 for loose LCD connection, How to check Fujifilm FinePix S8200 for loose LCD connection: 步骤 7 中的图像 1,1
    • Fold back the LCD screen and check that the cable coming from the screen is securely fastened to the motherboard.
  8. How to check Fujifilm FinePix S8200 for loose LCD connection: 步骤 8 中的图像 1,1
    • Fold the LCD screen back into the proper position.
结论
Joseph Kelley
于01/15/15注册
228 声望
创作了2篇指南
团队
USF Tampa, Team 7-1, Remmell Winter 2015 USF Tampa, Team 7-1, Remmell Winter 2015 的会员
USFT-REMMELL-W15S7G1
4 名成员
创作了9篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 3
总计 656
