跳转到主内容
How to charge Canon PowerShot A4000 IS battery
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
你所需要的
  1. How to charge Canon PowerShot A4000 IS battery, Battery: 步骤 1 中的图像 1,1
    • Using your finger, apply light pressure to the grooves at the top right corner of the camera to slide the door to the battery compartment open.
  2. How to charge Canon PowerShot A4000 IS battery, Inside The Battery Compartment: 步骤 2 中的图像 1,2 How to charge Canon PowerShot A4000 IS battery, Inside The Battery Compartment: 步骤 2 中的图像 2,2
    • Using your finger, press the red switch backwards, away from the lens to release the battery.
    • The battery has an arrow on it pointing in the direction the battery needs to be oriented in the camera.
  3. How to charge Canon PowerShot A4000 IS battery, Charging the Battery: 步骤 3 中的图像 1,3 How to charge Canon PowerShot A4000 IS battery, Charging the Battery: 步骤 3 中的图像 2,3 How to charge Canon PowerShot A4000 IS battery, Charging the Battery: 步骤 3 中的图像 3,3
    • Use the Battery Removal guide to remove your camera battery. Once the battery is removed, insert it into the charger that came with your PowerShot A4000 camera.
    • Maker sure the arrows on the charger and camera match up or the battery will not charge properly.
    • Once the battery is inserted into the charger, it is ready to be plugged into an outlet.
    • A yellow light will come on once the battery begins charging. The light will turn green when the battery is fully charged.
  4. How to charge Canon PowerShot A4000 IS battery, Reinserting the Battery: 步骤 4 中的图像 1,2 How to charge Canon PowerShot A4000 IS battery, Reinserting the Battery: 步骤 4 中的图像 2,2
    • Once the battery is fully charged, use the guide on removing your camera battery found here: Battery Removal, in reverse, to reinsert your battery.
    • Make sure to line up the battery with the arrow side facing toward the lens side of the camera. When you press the battery down, the red switch should click back into place automatically, holding the battery in place.
结论
Ansley Gardner
于10/13/14注册
761 声望
创作了7篇指南
团队
Clemson, Team 1-3, Benson Fall 2014 Clemson, Team 1-3, Benson Fall 2014 的会员
CLEM-BENSON-F14S1G3
3 名成员
创作了17篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 616
