跳转到主内容
How to change Tool for DeepAccess
你所需要的
  1. How to change Tool for DeepAccess, How to change Tool for DeepAccess: 步骤 1 中的图像 1,1
    • Prepare Tools and replacement parts.
  2. How to change Tool for DeepAccess, Remove wedge from transducer: 步骤 2 中的图像 1,3 How to change Tool for DeepAccess, Remove wedge from transducer: 步骤 2 中的图像 2,3 How to change Tool for DeepAccess, Remove wedge from transducer: 步骤 2 中的图像 3,3
    在这个步骤中使用的工具:
    • Grab wegdge with tweezers
    • Loosen the screw. (while holding the wedge)
    • Get rid of the copper screw. To NOT use it more than once
  3. How to change Tool for DeepAccess, Place the new wedge in the transducer.: 步骤 3 中的图像 1,3 How to change Tool for DeepAccess, Place the new wedge in the transducer.: 步骤 3 中的图像 2,3 How to change Tool for DeepAccess, Place the new wedge in the transducer.: 步骤 3 中的图像 3,3
    • Put the wedge in the tranducer from below.
    • Take care, that the Tool Top is flush with the Transducer surface
    • Correct Placement. Tool is flush with transducer.
    • Incorrect Placement. tool is too high.
  4. How to change Tool for DeepAccess, Fasten the copper screw: 步骤 4 中的图像 1,2 How to change Tool for DeepAccess, Fasten the copper screw: 步骤 4 中的图像 2,2
    • Fasten the screw lightly
    • Tighten the screw just so the wedge does not slip out of the tranducer.
    • in case of appliying too much torque. Use a new screw and get rid of the old one.
  5. How to change Tool for DeepAccess, Adjust wedge heigth with setting gauge: 步骤 5 中的图像 1,3 How to change Tool for DeepAccess, Adjust wedge heigth with setting gauge: 步骤 5 中的图像 2,3 How to change Tool for DeepAccess, Adjust wedge heigth with setting gauge: 步骤 5 中的图像 3,3
    • Place gauge below Tool
    • Loosen the screw so the wedge slides onto the gauge Lever.
    • Lift the gauge up until in contact with the transducer horn.
    • Now the Tool-Top should be flush with the Transducer-Horn
    • Tighten the screw with the torque- wrench
    • Use Torque wrench with 18cN limitation
    • Use tweezers to push the wire down the wire hole, until it Ends some cm below the tool wedge.
    • Use scissors to cut the (contaminated) Wire down to a length of about 1cm below wedge end.
  6. How to change Tool for DeepAccess, Thread Wire through Wedge-hole: 步骤 7 中的图像 1,3 How to change Tool for DeepAccess, Thread Wire through Wedge-hole: 步骤 7 中的图像 2,3 How to change Tool for DeepAccess, Thread Wire through Wedge-hole: 步骤 7 中的图像 3,3
    • Use tweezers to thread the wire through the hole at the end of the wedge.
    • Afet threading pull the wire some cm through the hole.
结论
Hans Panz
于03/10/16注册
289 声望
创作了2篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 141
