跳转到主内容
How to apply an Adhesive Bandage on a Fingertip
你所需要的
  1. How to apply an Adhesive Bandage on a Fingertip, Cut the bandage: 步骤 1 中的图像 1,3 How to apply an Adhesive Bandage on a Fingertip, Cut the bandage: 步骤 1 中的图像 2,3 How to apply an Adhesive Bandage on a Fingertip, Cut the bandage: 步骤 1 中的图像 3,3
    • Cut the bandage strip to length.
    • You need twice the length you want the bandage to cover. A 5 to 6 cm strip is usually enough for most small cuts.
    • Now, carefully cut a small triangle out of the bandage on both adhesive sides, up to the gauze pad. Cut the triangles out exactly in the middle. This will create four "little wings", as seen in the second picture.
  2. How to apply an Adhesive Bandage on a Fingertip, Peel off the protective films: 步骤 2 中的图像 1,2 How to apply an Adhesive Bandage on a Fingertip, Peel off the protective films: 步骤 2 中的图像 2,2
    • Peel off the protective films from the adhesive strip of the bandage.
  3. How to apply an Adhesive Bandage on a Fingertip, Apply the bandage: 步骤 3 中的图像 1,3 How to apply an Adhesive Bandage on a Fingertip, Apply the bandage: 步骤 3 中的图像 2,3 How to apply an Adhesive Bandage on a Fingertip, Apply the bandage: 步骤 3 中的图像 3,3
    • Place your finger on the bandage so that the tip of the finger meets the center line.
    • Fold up the two "little wings" on the side facing you one by one and secure them on the top side of the finger.
  4. How to apply an Adhesive Bandage on a Fingertip, Apply the bandage: 步骤 4 中的图像 1,3 How to apply an Adhesive Bandage on a Fingertip, Apply the bandage: 步骤 4 中的图像 2,3 How to apply an Adhesive Bandage on a Fingertip, Apply the bandage: 步骤 4 中的图像 3,3
    • Pull the bandage as tightly as possible over the fingertip towards the back and turn the finger with the underside facing upward.
    • Fold up the two remaining "little wings" one by one and secure them on the underside of the finger.
结论
If you have chosen the correct size of bandage, placed it properly, and pressed it firmly, it should now cover the entire fingertip. The wound should not come into contact with the adhesive surfaces.
5等其他人完成本指南。
Sebastian
于08/19/18注册
31,187 声望
创作了71篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 69
过去 7 天: 457
过去 30 天: 1,953
总计 28,488
