跳转到主内容
How to adjust the 2006 Iron Horse Warrior front derailleur
你所需要的
  1. How to adjust the 2006 Iron Horse Warrior front derailleur, How to adjust the 2006 Iron Horse Warrior front derailleur: 步骤 1 中的图像 1,1
    • Shift the front derailleur to the 1st position (smallest cog and closest to the body of the bike)
    • Adjust the "Low" screw with a screwdriver so the derailleur lines up vertically with the 1st gear.
    • Test your gears by holding your back tire off the ground and pedaling while you shift through your gears. If it is aligned correctly, the chain will not rub on the derailleur.
  2. How to adjust the 2006 Iron Horse Warrior front derailleur: 步骤 2 中的图像 1,1
    • Shift to 3rd gear (the largest cog and farthest from the body of the bike)
    • Adjust the derailleur until it lines up vertically with the 3rd gear
    • The same rules apply for this one as when setting the lower bound. However, you want the smallest gap possible between the outer edge of the chain and the guard. The smaller gap will allow your bike to downshift much easier.
    • The derailleur should be aligned now, but if you are unable to move the derailleur far enough away from the frame, you may need to tighten the cable itself. If so, proceed to Step 3.
  3. How to adjust the 2006 Iron Horse Warrior front derailleur: 步骤 3 中的图像 1,1
    • This step is only required if you were unable to align the derailleur in Step 2
    • To tighten the cable, place the derailleur in the 1st gear position. This position requires the least amount of tension on the cable.
    • Loosen the 6mm hex nut using an Allen wrench just enough to allow the cable to come free.
    • Pull the cable using your hands as tight as you can. Replace the cable under the screw and tighten the screw by turning it clockwise.
    • Repeat Step 2 to set the upper bound on the derailleur. Now that the cable is tight, the derailleur will be able to travel further away from the frame of the bike and line up with the 3rd gear.
结论
2等其他人完成本指南。
Matt Halvorson
于04/21/15注册
354 声望
创作了2篇指南
团队
Cal Poly, Team 15-2, Amido Spring 2015 Cal Poly, Team 15-2, Amido Spring 2015 的会员
CPSU-AMIDO-S15S15G2
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 11
总计 1,465
