跳转到主内容
How to adjust Triace A310 Brake Cable
你所需要的
  1. How to adjust Triace A310 Brake Cable, How to adjust Triace A310 Brake Cable: 步骤 1 中的图像 1,2 How to adjust Triace A310 Brake Cable, How to adjust Triace A310 Brake Cable: 步骤 1 中的图像 2,2
    • While holding onto the brake cable, unscrew the screw that holds the brake cable in place using a 5mm allen wrench.
  2. How to adjust Triace A310 Brake Cable: 步骤 2 中的图像 1,1
    • If you need to loosen your brakes, pull up on the arm while holding the brake cable in place.
    • To tighten your brakes follow the above step, except push down on the arm instead of pulling up.
  3. How to adjust Triace A310 Brake Cable: 步骤 3 中的图像 1,1
    • Tighten the screw on the desired location along the cable with the same 5mm allen wrench.
结论
You may need to repeat this process until your desired tension is achieved (trial and error).
Ben Hartinger
于01/27/14注册
340 声望
创作了3篇指南
团队
Cal Poly, Team 1-37, Maness Winter 2014 Cal Poly, Team 1-37, Maness Winter 2014 的会员
CPSU-MANESS-W14S1G37
4 名成员
创作了11篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 10
总计 278
