跳转到主内容
How to Upgrade CPU Core i5 to Core i7 on iMac Intel 27" Retina 5k Display
你所需要的
视频介绍
结论
To reassemble your device, follow these instructions.
7等其他人完成本指南。
Arty
于10/27/19注册
27,952 声望
创作了95篇指南
3指南评论
The method you use to remove the screen is very dangerous but the guide is helpful.
PJVCC - 回复
Good tutorial also useful to replace the SSD blade.
I would not change the processor and leave the creepy fusion drive, but
save the data, split the fusion drive, replace the SSD blade with a decent NVMe SSD (e.g. 512GB) to hold the OS and programs.
You may keep the HDD for your mass data or replace it with a SSD too.
The NVMe blade is however ways faster...
Laszlo Lebrun - 回复
Buenas noches, una pregunta, para una imac 5k 2017, con i5 7500, que procesadores le puedo poner si trae el socket 1151
Markuz Lirioz - 回复
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 27
过去 30 天: 129
总计 4,847
