跳转到主内容
How to manually Unload Filament on an Ender 3 Pro
  1. How to manually Unload Filament on an Ender 3 Pro, Setting the nozzle temperature: 步骤 1 中的图像 1,3 How to manually Unload Filament on an Ender 3 Pro, Setting the nozzle temperature: 步骤 1 中的图像 2,3 How to manually Unload Filament on an Ender 3 Pro, Setting the nozzle temperature: 步骤 1 中的图像 3,3
    • Press the knob to enter the marlin LCD menu and turn it to navigate between the options.
    • Navigate to Temperature > Nozzle.
    • Adjust the nozzle temperature by turning the knob and confirm by pressing it.
    • Use whatever temperature you would be printing with, minus about 10°C. For both PLA and PETG 210°C usually works fine.
  2. How to manually Unload Filament on an Ender 3 Pro, Wait for the hotend to heat up: 步骤 2 中的图像 1,1
    • Wait until the current temperature (bottom) matches the target temperature (top).
  3. How to manually Unload Filament on an Ender 3 Pro, Pull the filament: 步骤 3 中的图像 1,1
    • Press down on the extruder lever arm and pull out the loaded filament.
    • Fully pressing down the lever arm might lead to the filament snagging when you try to pull it out. Just pressing it a bit will usually suffice.
  4. How to manually Unload Filament on an Ender 3 Pro, Set cooldown: 步骤 4 中的图像 1,1
    • Navigate to Temperature and press Cooldown.
    • If you do not have the Cooldown-option available, you can just repeat step one and set the temperature to 0°C instead.
结论
This guide also applies to loading filament. You just need to push in the filament instead of pulling it out.
另外一个人完成了本指南。
Sebastian
于08/19/18注册
31,157 声望
创作了71篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 10
过去 30 天: 56
总计 2,041
