跳转到主内容
How to Unclog a Toilet Drainpipe
你所需要的
  1. How to Unclog a Toilet Drainpipe, How to Unclog a Toilet Drainpipe: 步骤 1 中的图像 1,1
    • Turn off the water supply.
    • The switch of water supply may locate differently depends on different pipe structure. Find it either left or right of toilet bowl on the floor.
  2. How to Unclog a Toilet Drainpipe: 步骤 2 中的图像 1,1
    • Flush the toilet in order to empty the water tank and the bowl.
  3. How to Unclog a Toilet Drainpipe: 步骤 3 中的图像 1,1
    • Use a sponge or paper towel to clean the water left in the water tank.
    • Make sure you wear the gloves.
  4. How to Unclog a Toilet Drainpipe: 步骤 4 中的图像 1,1
    • Remove the water supply pipe from the toilet bowl.
  5. How to Unclog a Toilet Drainpipe: 步骤 5 中的图像 1,3 How to Unclog a Toilet Drainpipe: 步骤 5 中的图像 2,3 How to Unclog a Toilet Drainpipe: 步骤 5 中的图像 3,3
    • Find the floor bolts and remove the decorative cap off the bolts.
    • Remove the bolts with a wrench.
  6. How to Unclog a Toilet Drainpipe: 步骤 6 中的图像 1,1
    • After removing the floor bolts, wiggle the bowl and remove it.
    • Remove anything that may be stuck in the pipe.
结论
另外一个人完成了本指南。
Chen Liang
于07/08/20注册
160 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 20
过去 30 天: 62
总计 1,186
