简介
In this guide, I will explain how to remove buildup in the shower drain.
你所需要的
Begin by putting on a pair of disposable gloves to protect your hands from what is inside your drain and from the chemicals in drain opener.
Once the drain stopper is out of the way, use your fingers, tweezers, or almost any long thin object to pull out hair and larger items clogging the drain.
Dispose of anything you were able to remove from your drain.
If you cannot remove your drain stopper, skip ahead until step 7.
To reassemble your drain stopper, follow the steps you took in step one in reverse order.
2等其他人完成本指南。
