跳转到主内容
How to Unclog a Keurig BVMC-KG5
你所需要的
  1. How to Unclog a Keurig BVMC-KG5, How to Unclog a Keurig BVMC-KG5: 步骤 1 中的图像 1,1
    • Unplug your Keurig.
  2. How to Unclog a Keurig BVMC-KG5: 步骤 2 中的图像 1,1
    • Disassemble all of the parts. This includes: water tank, lid, K-cup holder, and both pieces of the tray where the coffee cup sits.
    • You should not need a screwdriver for this. All of the parts you are disassembling are easily removable by hand.
    • Wash all of the parts in warm, soapy water. Dry well.
  3. How to Unclog a Keurig BVMC-KG5: 步骤 3 中的图像 1,3 How to Unclog a Keurig BVMC-KG5: 步骤 3 中的图像 2,3 How to Unclog a Keurig BVMC-KG5: 步骤 3 中的图像 3,3
    • Unclog the needles using a slightly bent paperclip.
    • With the top of the Keuring open, insert the free end of the paperclip into the three small holes surrounding the needle that pierces the K-Cup.
    • Jiggle the paperclip to loosen any debris.
  4. How to Unclog a Keurig BVMC-KG5: 步骤 4 中的图像 1,1
    • Wipe the whole machine down and reassemble all of the previously removed parts.
  5. How to Unclog a Keurig BVMC-KG5: 步骤 5 中的图像 1,1
    • Fill the water tank with a half water-half vinegar solution.
    • Do not use straight vinegar. It can damage the machine's parts due to the acidity.
    • Run the water-vinegar solution through the machine until you have emptied the tank.
    • Run clean water through the machine. You may have to repeat this step several times to get all of the water-vinegar solution out of the pipes.
结论
Repeat this process every 2-3 months for optimal use of your Keurig, and to increase the lifespan of your coffee brewer.
2等其他人完成本指南。
团队
Michigan Tech, Team 1-1, Lauer Spring 2016 Michigan Tech, Team 1-1, Lauer Spring 2016 的会员
MTU-LAUER-S16S1G1
1 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 23
总计 5,665
