跳转到主内容
How to Unclog a Fountain Pen
你所需要的
  1. How to Unclog a Fountain Pen, How to Unclog a Fountain Pen: 步骤 1 中的图像 1,2 How to Unclog a Fountain Pen, How to Unclog a Fountain Pen: 步骤 1 中的图像 2,2
    • Disassemble the fountain pen.
  2. How to Unclog a Fountain Pen: 步骤 2 中的图像 1,2 How to Unclog a Fountain Pen: 步骤 2 中的图像 2,2
    • Remove the ink cartridge from the section.
    • Run the section under warm running water.
  3. How to Unclog a Fountain Pen: 步骤 3 中的图像 1,3 How to Unclog a Fountain Pen: 步骤 3 中的图像 2,3 How to Unclog a Fountain Pen: 步骤 3 中的图像 3,3
    • Remove the feed and nib from the section.
    • Separate the nib and the feed.
    • Run the nib and feed under warm water and use a soft bristle toothbrush to gently scrub the ink residue on the two pieces.
  4. How to Unclog a Fountain Pen: 步骤 4 中的图像 1,1
    • Leave the nib, feed, and section to air dry until completely dry.
    • Reassemble and test the pen
    • If the fountain pen still does not work, continue to Step 5.
  5. How to Unclog a Fountain Pen: 步骤 5 中的图像 1,3 How to Unclog a Fountain Pen: 步骤 5 中的图像 2,3 How to Unclog a Fountain Pen: 步骤 5 中的图像 3,3
    • To create the cleaning solution, mix equal parts of ammonia and water in a container.
    • Add a few drops of dish soap to the solution and stir.
  6. How to Unclog a Fountain Pen: 步骤 6 中的图像 1,3 How to Unclog a Fountain Pen: 步骤 6 中的图像 2,3 How to Unclog a Fountain Pen: 步骤 6 中的图像 3,3
    • Drop the nib and feed in the cleaning solution.
    • Soak the pieces for approximately 12-24 hours.
  7. How to Unclog a Fountain Pen: 步骤 7 中的图像 1,1
    • Leave the nib, feed, and section to airdry until completely dry.
  8. How to Unclog a Fountain Pen: 步骤 8 中的图像 1,3 How to Unclog a Fountain Pen: 步骤 8 中的图像 2,3 How to Unclog a Fountain Pen: 步骤 8 中的图像 3,3
    • When it's dry, replace the ink cartridge or converter and reassemble the fountain pen.
结论
Reassemble your fountain pen and you are ready to write.
Mara Alagon
于01/30/24注册
157 声望
撰写一个指南
团队
UC Davis, Team 2-2, Andersen Winter 2024 UC Davis, Team 2-2, Andersen Winter 2024 的会员
UCD-ANDERSEN-W24S2G2
3 名成员
创作了2篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 43
过去 30 天: 153
总计 1,608
