跳转到主内容
How to Unclog Epson Workforce 2760 Ink Heads
你所需要的
  1. How to Unclog Epson Workforce 2760 Ink Heads, How to Unclog Epson Workforce 2760 Ink Heads: 步骤 1 中的图像 1,3 How to Unclog Epson Workforce 2760 Ink Heads, How to Unclog Epson Workforce 2760 Ink Heads: 步骤 1 中的图像 2,3 How to Unclog Epson Workforce 2760 Ink Heads, How to Unclog Epson Workforce 2760 Ink Heads: 步骤 1 中的图像 3,3
    • In the "Settings" menu, set the printer cartridges to "Replace ink cartridges."
  2. How to Unclog Epson Workforce 2760 Ink Heads: 步骤 2 中的图像 1,3 How to Unclog Epson Workforce 2760 Ink Heads: 步骤 2 中的图像 2,3 How to Unclog Epson Workforce 2760 Ink Heads: 步骤 2 中的图像 3,3
    • Move the cartridge to the side.
    • Place a towel underneath.
  3. How to Unclog Epson Workforce 2760 Ink Heads: 步骤 3 中的图像 1,2 How to Unclog Epson Workforce 2760 Ink Heads: 步骤 3 中的图像 2,2
    • Place the cleaning solution of 100 mL in a cup of hot boiling water, with the cap off to avoid air pressure that can damage the solution.
  4. How to Unclog Epson Workforce 2760 Ink Heads: 步骤 4 中的图像 1,3 How to Unclog Epson Workforce 2760 Ink Heads: 步骤 4 中的图像 2,3 How to Unclog Epson Workforce 2760 Ink Heads: 步骤 4 中的图像 3,3
    • Pull 5 mL of the hot solution using the syringe.
    • Apply the solution to the black printer head first.
    • After applying the solution, wait one hour for the solution to break down the dried ink.
  5. How to Unclog Epson Workforce 2760 Ink Heads: 步骤 5 中的图像 1,3 How to Unclog Epson Workforce 2760 Ink Heads: 步骤 5 中的图像 2,3 How to Unclog Epson Workforce 2760 Ink Heads: 步骤 5 中的图像 3,3
    • After one hour, repeat steps one through four on the other ink heads.
    • Move the ink slot back into place, and insert the new ink cartridges.
    • Under "Settings," finish replacing ink cartridges process.
    • Print a "test page" and if the results shown on image three appear, the printer heads are successfully unclogged.
终点
Cristian Rodriguez
于10/26/22注册
253 声望
撰写一个指南
团队
CSU Los Angeles, Team 1-1, Briggs Fall 2023 CSU Los Angeles, Team 1-1, Briggs Fall 2023 的会员
CSULA-BRIGGS-F23S1G1
6 名成员
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 13
过去 30 天: 57
总计 674
