简介
So, your 2009-2012 27" iMac suddenly won't power on, you tried everything: resetting PRAM, rebooting, cleaning RAM, etc.
Your machine is gone probably because of overheating which desoldered your CPU/GPU (90% of the cases) or because of some desoldered/fried component on the logic board.
You don't want to repair it because it would cost too much/it's too old.
But hey, everything's not lost, you can turn your dead iMac into an external display!
You need just an LCD driver board, some basic tools and lots of patience.
!! DISCLAIMER !!
THIS GUIDE INVOLVES INTERACTING WITH HIGH VOLTAGE EQUIPMENT, DON'T TRY UNLESS YOU KNOW WHAT YOU'RE DOING!
For disassembling you can refer to the perfectly made iFixit teardown guide iMac Intel 27" EMC 2309 and 2374 Teardown
Check on the back of your display the brand and model of it
It will probably be an LG display
Mine was model LM270WQ1 (SD)(C2)
Search for a LCD driver board compatible with your display
I found one on AliEx for about 25€ LM270WQ1 (S2)(C2) LCD Driver Board
Now you have to plan what you want to use
If you want you can use the iMac PSU by repurposing it [WARNING! DO IT ONLY IF YOU KNOW HOW TO HANDLE HIGH VOLTAGE!]
You can check in the next step how to do it
Otherwise you can buy a simple 12V-5A brick PSU and use that one
You can also re-use the iMac internal speakers and play audio via HDMI
The iMac PSU has a 16-pin connector and the number of the pin is printed on the connector itself (green circles)
You will need pins 4 & 8 in this case
Pin 4 (yellow) is 12V and we have PP12V_G3H_ACDC: that's the power the PSU gives when it's connected to the outlet (the same that powers LED #1 on the logic board)
Pin 8 (red) is GND
Always check with a DMM if you have the right voltage!
I cutted the two wires and (temporarily) soldered them onto the board 12V and GND pads.
In the next future I will buy a 5.5x2.1 DC connector and solder the two cables there, so I can plug the connector directly in the DC female connector of the board, that's the best way to do it
The iMac internal speakers have 4 wires each, 2 for the tweeters and 2 for the woofers
Connect white-white and brown-black together
Then here you can choose: you can use a JST male connector following the pinout and connect it to the board (easiest way) or you can desolder the JST female and solder the wires directly onto the board
The dark wires are the positive (+) and the white ones are the negative (-)
On the driver board you have negatives on the outside and positives on the inside
VORN/VORP are right negative/right positive while VOLN/VOLP are left negative/left positive
NB You'll probably hear some strange sounds from the speakers once you turn on everything and you use audio over HDMI, that's probably due to the poor quality of the audio amp stage of the board. But it works and it's cheap, so it's ok.
Now you have to mount the boards inside the chassis
You can follow my positioning, I found it to be very comfortable
Main board on the left side where the right fan was positioned
Inverter board with backside visible (so it won't interfere with the display) screwed with the bottom-left screw of the power supply
For this you have to break a little piece of the plastic piece that was separating the PSU from the original iMac inverter board
In the first image you can see how to connect the controller board to the chassis
I re-used one of the screw that was holding the RAM aluminum panel in place
You can also use the original iMac power button! Just cut it where the connector is and solder the two wires on the corresponding pads of the control board, where the power button is, like I did
This way you can turn on and off the screen using the original power button
I also found this nice 3D print project for the EH1406 controller board, in the next future I'll add it to the iMac display since I think it's nicer that way EH1406 3D Print
I don't need the VGA connection, so I'll use only the HDMI connection
You can use a long cable, connect it to the board and let it out from the chassis
Or you can also buy an HDMI extender cable and connect it like I did (it's more practical to have a detachable HDMI cable)
Now you have to connect the inverter and LVDS cables
They have only one way to connect so you can't go wrong
Once you did it, everything is ready!
Put the display in place and fix it with two screws (top left and bottom right) so it doesn't move
Now connect your PSU (if you used an external one) or you original iMac cable (if you re-purposed the original PSU)
The display should turn on and do an RGB test (should cycle with different colours changing every 2-3 seconds) while the controller board green LED should light up
Reduce
Reuse
Recycle
Reduce
Reuse
Recycle
另外一个人完成了本指南。
