跳转到主内容
How to Turn a Loop - Eye Pin Technique
你所需要的
  1. How to Turn a Loop - Eye Pin Technique, Thread and Bend: 步骤 1 中的图像 1,1
    • Thread a bead onto your eye pin.
    • Using your chain nose pliers, make a 90 degree bend just above your bead.
  2. How to Turn a Loop - Eye Pin Technique, Remove Excess Pin Tail: 步骤 2 中的图像 1,1
    • Use side cutters to cut the wire, leaving a tail that's about one third of an inch long.
  3. How to Turn a Loop - Eye Pin Technique, Turn the Loop: 步骤 3 中的图像 1,1
    • Position your round nose pliers at the end of the tail, making sure the tail faces away from your body. Wrap the wire towards you to create a loop.
  4. How to Turn a Loop - Eye Pin Technique, Align Loops: 步骤 4 中的图像 1,1
    • When making a link like this you'll want both loops to face the same direction. To do this, grip each loop with a pair of chain nose pliers and just twist until your loops are where you want them.
  5. How to Turn a Loop - Eye Pin Technique, Opening and Closing the Loop: 步骤 5 中的图像 1,1
    • To open and close the loop, you can use chain nose pliers and gently twist it open from side to side.
结论
Practicing these steps will help you to get the loop tight against the bead, and the loop size consistent.
2等其他人完成本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 41
总计 2,108
