跳转到主内容
How to True a wheel
你所需要的
  1. How to True a wheel, How to True a wheel: 步骤 1 中的图像 1,2 How to True a wheel, How to True a wheel: 步骤 1 中的图像 2,2
    • Fit the wheel into the wheel truing stand.
    • The wheel should be snug and securely fixed to the stand.
    • Make sure hub does not have play in it since this will impede your ability to true the wheel.
  2. How to True a wheel: 步骤 2 中的图像 1,2 How to True a wheel: 步骤 2 中的图像 2,2
    • Slowly rotate the wheel.
    • Slowly tighten the calipers until they touch at some point on only one side of the rim.
  3. How to True a wheel: 步骤 3 中的图像 1,2 How to True a wheel: 步骤 3 中的图像 2,2
    • Select the a spoke wrench that fits the spokes on your wheel.
    • Loosen the spokes that attach to the same side of the wheel as the caliper contact point. At the same time, tighten the spokes that attach to the opposite side of the wheel as the caliper contact point. To start, try a half turn for each of the spokes near the caliper contact point.
    • In the photo, the red marked spokes are being tightened, and the blue marked spokes are being loosened. This will shift the rim closer to the viewer.
    • Spin the wheel. Tighten the calipers again until they touch the rim on only one side at a time at certain point. Repeat steps 2-3 until when tightening the calipers, they touch both sides of the rim evenly at every point on the rim.
结论
The wheel should spin without wobbling from side to side or wavering up and down.
另外一个人完成了本指南。
aaron thielk
于10/10/10注册
1,903 声望
创作了5篇指南
团队
Cal Poly, Team 5-13, Maness Fall 2010 Cal Poly, Team 5-13, Maness Fall 2010 的会员
CPSU-MANESS-F10S5G13
4 名成员
创作了17篇指南
2条评论
This is a great instruction manual. I especially appreciated the pictures. For those of us who have never fixed a bike, I would not know what a caliper was without the picture.
Thanks!
edwardslaura234 - 回复
If you don't want to spend money on wheel callipers. Use clothes hanger and tape to the break as a guide.
deankjm - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 7,445
