跳转到主内容
How to True a Bent Bicycle Rim Using Common Tools
你所需要的
  1. How to True a Bent Bicycle Rim Using Common Tools, How to True a Bent Bicycle Rim Using Common Tools: 步骤 1 中的图像 1,1
    • Bring your bike somewhere with ample space so you have room to work.
  2. How to True a Bent Bicycle Rim Using Common Tools: 步骤 2 中的图像 1,3 How to True a Bent Bicycle Rim Using Common Tools: 步骤 2 中的图像 2,3 How to True a Bent Bicycle Rim Using Common Tools: 步骤 2 中的图像 3,3
    • Flip the bike on its seat so the wheel can spin freely.
    • Use the spokes to spin the affected wheel.
    • Continue spinning the wheel until it is clear where the bend is occurring.
  3. How to True a Bent Bicycle Rim Using Common Tools: 步骤 3 中的图像 1,2 How to True a Bent Bicycle Rim Using Common Tools: 步骤 3 中的图像 2,2
    • Locate the bend by spinning the wheel to see where it doesn't align with the brake.
  4. How to True a Bent Bicycle Rim Using Common Tools: 步骤 4 中的图像 1,3 How to True a Bent Bicycle Rim Using Common Tools: 步骤 4 中的图像 2,3 How to True a Bent Bicycle Rim Using Common Tools: 步骤 4 中的图像 3,3
    • Locate the two nearest spoke nipples opposite to the bend direction and tighten them a half turn using an adjustable wrench or reaming pliers.
  5. How to True a Bent Bicycle Rim Using Common Tools: 步骤 5 中的图像 1,2 How to True a Bent Bicycle Rim Using Common Tools: 步骤 5 中的图像 2,2
    • Pluck the spoke and listen to the pitch to check its tightness.
    • If the pitch is higher, you are tightening it, and if the pitch is lower, you are loosening it.
  6. How to True a Bent Bicycle Rim Using Common Tools: 步骤 6 中的图像 1,2 How to True a Bent Bicycle Rim Using Common Tools: 步骤 6 中的图像 2,2
    • Loosen the spoke nipples opposite to the ones being tightened to reduce stress in the wrong direction.
  7. How to True a Bent Bicycle Rim Using Common Tools: 步骤 7 中的图像 1,1
    • Assess the dent in the bike rim and assure it's mostly straightened out relative to the break pad.
    • Repeat the tightening/loosening process accordingly if necessary.
结论
另外一个人完成了本指南。
Charles Tweedy
于04/19/23注册
163 声望
撰写一个指南
团队
UCD-MORRIS-S23S1G4 UCD-MORRIS-S23S1G4 的会员
Community
2 名成员
创作了1篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 42
总计 1,480
