跳转到主内容
How to Tighten the Nishiki Aero II Chain
  1. How to Tighten the Nishiki Aero II Chain, How to Tighten the Nishiki Aero II Chain: 步骤 1 中的图像 1,1
    • Shift the rear derailleur into its outermost gear, and the front derailleur into its outer gear.
  2. How to Tighten the Nishiki Aero II Chain: 步骤 2 中的图像 1,3 How to Tighten the Nishiki Aero II Chain: 步骤 2 中的图像 2,3 How to Tighten the Nishiki Aero II Chain: 步骤 2 中的图像 3,3
    • Open the quick-release lever on the rear axle.
    • Quick-release levers are designed to allow you to remove a wheel by hand, with no tools.
    • Continue to loosen the axle by hand until you can freely move the axle in its notch in the rear fork.
  3. How to Tighten the Nishiki Aero II Chain: 步骤 3 中的图像 1,1
    • Move the axle farther back along the notch in the fork so that the chain is taught between the cogs.
    • You might want to ask a friend to help you keep everything steady.
    • Be careful when choosing the new position for the axle; make sure that the wheel will be aligned with the frame.
  4. How to Tighten the Nishiki Aero II Chain: 步骤 4 中的图像 1,1
    • Now that the axle is placed correctly, re-tighten the axle and re-apply the quick-release as shown in Step 1.
结论
Tobias Elder
于04/25/13注册
113 声望
创作了7篇指南
团队
Cal Poly, Team 21-53, Johann Spring 2013 Cal Poly, Team 21-53, Johann Spring 2013 的会员
CPSU-JOHANN-S13S21G53
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 20
总计 1,380
