跳转到主内容
How to Tighten Loose Bike Spokes
你所需要的
  1. How to Tighten Loose Bike Spokes, How to Tighten Loose Bike Spokes: 步骤 1 中的图像 1,3 How to Tighten Loose Bike Spokes, How to Tighten Loose Bike Spokes: 步骤 1 中的图像 2,3 How to Tighten Loose Bike Spokes, How to Tighten Loose Bike Spokes: 步骤 1 中的图像 3,3
    • Place the bike in a position where you can comfortably access the wheel.
  2. How to Tighten Loose Bike Spokes: 步骤 2 中的图像 1,1
    • Inspect the wheel and look for loose spokes.
  3. How to Tighten Loose Bike Spokes: 步骤 3 中的图像 1,3 How to Tighten Loose Bike Spokes: 步骤 3 中的图像 2,3 How to Tighten Loose Bike Spokes: 步骤 3 中的图像 3,3
    • Use a spoke wrench to tighten the spoke. Retighten the spoke clockwise a quarter turn at a time.
  4. How to Tighten Loose Bike Spokes: 步骤 4 中的图像 1,2 How to Tighten Loose Bike Spokes: 步骤 4 中的图像 2,2
    • Since you just adjusted the tension of a spoke, we need to make sure the tension in all the spokes is equal throughout.
    • Use the spoke wrench to adjust the rest of the spokes as needed so that they all have equal tension. Turn the spoke wrench clockwise a quarter at a time.
  5. How to Tighten Loose Bike Spokes: 步骤 5 中的图像 1,1
    • Once the spokes are tightened, relieve the tension in the spokes by squeezing them.
    • This is to check that your spokes are now secure and won’t get loose.
    • Be sure to give the loose spokes an extra test to make sure they are now sturdy.
  6. How to Tighten Loose Bike Spokes: 步骤 6 中的图像 1,1
    • Spin the wheel to make sure the spokes are secure and to make sure that the wheel does not need additional truing.
终点
另外一个人完成了本指南。
Pavle Janev
于01/12/22注册
160 声望
撰写一个指南
团队
一条评论
You should notice the tension spoke when tightening your bike spoke because it will affect the wheel’s stability. Tighten clockwise and turning the wrench in small increments of about a quarter turn will allow you to avoid tightening too much.
Dalton - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 35
过去 30 天: 167
总计 5,543
