跳转到主内容
How to Tighten GEN 2 Wheelchair Wheels
你所需要的
  1. How to Tighten GEN 2 Wheelchair Wheels, How to Tighten GEN 2 Wheelchair Wheels: 步骤 1 中的图像 1,1
    • Inspect the chair to see which wheel is loose.
    • Tighten the outer bolt with a 19 mm socket wrench.
  2. How to Tighten GEN 2 Wheelchair Wheels: 步骤 2 中的图像 1,1
    • Tighten the nut facing the inside of the chair with a 19 mm wrench.
结论
If wheel does not feel properly secured, keep tightening the wheel in small amounts until the wheel is secure.
Kali Slaughter
于04/19/13注册
207 声望
创作了5篇指南
团队
Cal Poly, Team 14-8, Maness Spring 2013 Cal Poly, Team 14-8, Maness Spring 2013 的会员
CPSU-MANESS-S13S14G8
5 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 19
总计 1,922
