跳转到主内容
How to Tie a Tie: Trinity
你所需要的
  1. How to Tie a Tie: Trinity, Preparation: 步骤 1 中的图像 1,1
    • Fold the collar of your shirt up.
  2. How to Tie a Tie: Trinity: 步骤 2 中的图像 1,1
    • Wrap the tie around the back of your neck with the wide end on the left side of your body and the narrow end on the right side.
    • The narrow end of the tie will be your active end.
    • Note: The wide end of the tie should be around the height of your belly button or a little higher. It may need to adjusted for personal height.
  3. How to Tie a Tie: Trinity, Tying: 步骤 3 中的图像 1,1
    • Take the active end and it cross over the wide end, so it is pointing to the left.
    • Note: be sure that the tie always lays flat so that there are no twists in the fabric.
    • Note: Be sure to keep this wrap and all subsequent wraps tight against one another.
  4. How to Tie a Tie: Trinity: 步骤 4 中的图像 1,2 How to Tie a Tie: Trinity: 步骤 4 中的图像 2,2
    • Wrap active end under the left side and up through the neck loop, so that it points up.
  5. How to Tie a Tie: Trinity: 步骤 5 中的图像 1,2 How to Tie a Tie: Trinity: 步骤 5 中的图像 2,2
    • Wrap the active end over the left side again, so that it now points down.
  6. How to Tie a Tie: Trinity: 步骤 6 中的图像 1,1
    • Wrap the active end under the wide end of the tie, so that it now points towards the right.
  7. How to Tie a Tie: Trinity: 步骤 7 中的图像 1,1
    • Wrap the active end over the knot, so that it now points up.
  8. How to Tie a Tie: Trinity: 步骤 8 中的图像 1,1
    • Wrap the active end down through the neck loop, and pull to the left side, so that it now points left.
  9. How to Tie a Tie: Trinity: 步骤 9 中的图像 1,1
    • Wrap the active end over the wide end of your tie.
    • Note: leave this wrap a little loose as it will be used in step 11.
  10. How to Tie a Tie: Trinity: 步骤 10 中的图像 1,1
    • Wrap the active end under the right side and up through the neck loop, so that it points up.
  11. How to Tie a Tie: Trinity: 步骤 11 中的图像 1,2 How to Tie a Tie: Trinity: 步骤 11 中的图像 2,2
    • Pull the active end down through the wrap you made in step 9 (see picture 2). Then pull the active end so that it points left.
    • Note: leave this new wrap a little loose as it will be used in step 13.
  12. How to Tie a Tie: Trinity: 步骤 12 中的图像 1,2 How to Tie a Tie: Trinity: 步骤 12 中的图像 2,2
    • Wrap the active end under the wide tie to the right, so that the active end is pointing right.
    • Note: be sure that is tucked completely behind the wide end.
  13. How to Tie a Tie: Trinity: 步骤 13 中的图像 1,3 How to Tie a Tie: Trinity: 步骤 13 中的图像 2,3 How to Tie a Tie: Trinity: 步骤 13 中的图像 3,3
    • Wrap active end over the knot and pull through the diagonal wrap you made in step 11 (see picture 3).
  14. How to Tie a Tie: Trinity, Finishing: 步骤 14 中的图像 1,1
    • Tighten the neck knot by holding the knot and pulling on the narrow end of the tie away from you.
  15. How to Tie a Tie: Trinity: 步骤 15 中的图像 1,1
    • Tighten the neck loop by pulling down on the wide end of the tie and sliding the knot up toward your neck.
  16. How to Tie a Tie: Trinity: 步骤 16 中的图像 1,3 How to Tie a Tie: Trinity: 步骤 16 中的图像 2,3 How to Tie a Tie: Trinity: 步骤 16 中的图像 3,3
    • Tuck the rest of the narrow end into your collar and fold your collar down.
结论
Congratulations! You've successful tied the Trinity knot!
3等其他人完成本指南。
团队
The Electric Warthogs The Electric Warthogs 的会员
Community
3 名成员
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 33
总计 872
