跳转到主内容
How to Tie a Tie: Prince Albert
你所需要的
  1. How to Tie a Tie: Prince Albert, Preparation: 步骤 1 中的图像 1,1
    • Fold the collar of your shirt up.
  2. How to Tie a Tie: Prince Albert: 步骤 2 中的图像 1,1
    • Wrap the tie around the back of your neck with the narrow end on the left side of your body and the wide end on the right side.
    • The wide end of the tie will be your active end.
    • Note: the narrow end of the tie should be around the height of your belly button or a little higher. It may need to adjusted for personal height.
  3. How to Tie a Tie: Prince Albert, Tying: 步骤 3 中的图像 1,1
    • Take the active end and cross it over the narrow end, so that it points to the left.
    • Note: be sure that the tie always lays flat so there are no twists in the fabric.
  4. How to Tie a Tie: Prince Albert: 步骤 4 中的图像 1,1
    • Wrap active end under the narrow end, so that it now points to the right.
    • Note: leave this wrap, and subsequent wraps, a little loose.
  5. How to Tie a Tie: Prince Albert: 步骤 5 中的图像 1,1
    • Wrap the active end over the narrow end, so that it now points to the left.
    • Note: Leave this wrap a little loose as it will be used in step 9.
  6. How to Tie a Tie: Prince Albert: 步骤 6 中的图像 1,1
    • Wrap the active end under the narrow end, so that it now points to the right.
  7. How to Tie a Tie: Prince Albert: 步骤 7 中的图像 1,1
    • Note: Leave this wrap a little loose, as it will be used in step 9.
  8. How to Tie a Tie: Prince Albert: 步骤 8 中的图像 1,1
    • Pull the active end up through the neck loop, so that it now points up.
  9. How to Tie a Tie: Prince Albert: 步骤 9 中的图像 1,3 How to Tie a Tie: Prince Albert: 步骤 9 中的图像 2,3 How to Tie a Tie: Prince Albert: 步骤 9 中的图像 3,3
    • Pull the active end down through the wraps you created in steps 5 (see image 2) and 7 (see image 3).
  10. How to Tie a Tie: Prince Albert, Finishing: 步骤 10 中的图像 1,1
    • Tighten the knot by pulling down on the active end and up on the knot, adjusting for size and evenness.
  11. How to Tie a Tie: Prince Albert: 步骤 11 中的图像 1,1
    • Tighten the neck loop by pulling down on the narrow end of the tie and sliding the knot up toward your neck.
  12. How to Tie a Tie: Prince Albert: 步骤 12 中的图像 1,1
    • Tuck the narrow end of the tie through the keeper loop.
    • Note: if the narrow end is too long, a simple solution lies in tucking the narrow end between two buttons of your shirt.
    • Fold your collar down when the knot is finished.
结论
Congratulations! You've successfully tied the Prince Albert knot!
2等其他人完成本指南。
Wes
于03/29/17注册
514 声望
创作了2篇指南
团队
The Electric Warthogs The Electric Warthogs 的会员
Community
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 16
总计 423
