跳转到主内容
How to Tie a Tie: Pratt
你所需要的
  1. How to Tie a Tie: Pratt, Preparation: 步骤 1 中的图像 1,1
    • Fold the collar of your shirt up.
  2. How to Tie a Tie: Pratt: 步骤 2 中的图像 1,1
    • Wrap the tie around the back of your neck with the narrow end on the left side of your body and the wide end on the right side.
    • The wide end of the tie will be your active end.
    • Note: the narrow end of the tie should be around the height of your belly button or a little higher. It may need to adjusted for personal height.
  3. How to Tie a Tie: Pratt, Tying: 步骤 3 中的图像 1,1
    • Take the active end and cross it under the narrow end, so that it points to the left.
    • Note: be sure that the tie always lays flat so there are no twists in the fabric.
  4. How to Tie a Tie: Pratt: 步骤 4 中的图像 1,1
    • Lift the active end up, so that it is now pointing up.
  5. How to Tie a Tie: Pratt: 步骤 5 中的图像 1,2 How to Tie a Tie: Pratt: 步骤 5 中的图像 2,2
    • Pull the active end down through the loop around your neck, so that it is now pointing down and to the left.
  6. How to Tie a Tie: Pratt: 步骤 6 中的图像 1,1
    • Cross the active end over the front of the knot, so that it is now pointing to the right.
    • Note: leave this wrap a little loose, as it will be used in step 8.
  7. How to Tie a Tie: Pratt: 步骤 7 中的图像 1,1
    • Pull the active end up through the neck loop, so that it is now pointing up.
  8. How to Tie a Tie: Pratt: 步骤 8 中的图像 1,2 How to Tie a Tie: Pratt: 步骤 8 中的图像 2,2
    • Pull the active end down through the wrap you created in step 6 (see second picture).
  9. How to Tie a Tie: Pratt, Finishing: 步骤 9 中的图像 1,1
    • Tighten the knot by pulling down on the active end and up on the knot, adjusting for size and evenness.
  10. How to Tie a Tie: Pratt: 步骤 10 中的图像 1,1
    • Tighten the neck loop by pulling down on the narrow end of the tie and sliding the knot up toward your neck.
  11. How to Tie a Tie: Pratt: 步骤 11 中的图像 1,1
    • Tuck the narrow end of the tie through the keeper loop.
    • Note: if the narrow end is too long, a simple solution lies in tucking the narrow end between two buttons of your shirt.
    • Fold your collar down when the knot is finished.
结论
Congratulations! You've successfully tied the Pratt knot!
3等其他人完成本指南。
Wes
于03/29/17注册
514 声望
创作了2篇指南
团队
The Electric Warthogs The Electric Warthogs 的会员
Community
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 27
总计 563
