跳转到主内容
How to Test the Valve System on a Fisher Paykel Neopuff
医疗设备
ifixit 或本维修指南均未获得医疗设备制造商的认可或与任何制造商存在附属关系。
    • Set the gas supply to 5 L/min.
  1. How to Test the Valve System on a Fisher Paykel Neopuff: 步骤 2 中的图像 1,1
    • Completely close the Peak Inspiratory Pressure control and the Max Pressure control by turning both knobs completely clockwise.
  2. How to Test the Valve System on a Fisher Paykel Neopuff: 步骤 3 中的图像 1,1
    • Close the bleed valve and check that the gauge reads at least 60 cmh2O.
    • Set the gas supply to 15 L/min.
  3. How to Test the Valve System on a Fisher Paykel Neopuff: 步骤 5 中的图像 1,1
    • Close the bleed valve and check that the gauge reads no higher than 80 cmH2O.
    • Set the gas supply to 10 L/min.
    • Close the bleed valve and turn the Max Pressure Relief valve until the manometer reads 40 cmh2O.
    • Check that the manometer needle rises and falls smoothly.
    • Gently rotate the Max Pressure Relief cover over the Max Pressure Relief knob.
  4. How to Test the Valve System on a Fisher Paykel Neopuff: 步骤 10 中的图像 1,1
    • Reset the peak inspiratory pressure to 20 cmh2O and turn off the gas flow. Testing is now complete. If the F&P Neopuff/Perivent Infant Resuscitator fails any of these tests, the valve assembly should be regarded as faulty and replaced with a new valve assembly (see the parts list (section 4.1.2) for part numbers).
结论
另外一个人完成了本指南。
Constantine Yap
于05/04/20注册
364 声望
创作了2篇指南
团队
Cal Poly, Team S1-G6, Zimmerman Spring 2020 Cal Poly, Team S1-G6, Zimmerman Spring 2020 的会员
CPSU-ZIMMERMAN-S20S1G6
4 名成员
创作了27篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 8
总计 753
