跳转到主内容
加入维修社区 - 创建账户
How to Test a Capacitor with a Multimeter
浏览量: 5385
浏览统计数据:
过去24小时
94
过去 7 天:
632
过去 30 天:
2,382
总计
5,385
评论: 1
1 guide comment.
Go to guide comments
已完成: 3
3 人已将本指南标记为“已完成”。你会是下一个完成的人吗?
收藏: 0
暂时还没有人收藏(和订阅)本指南。你会是第一个收藏(和订阅)的人吗?
所需时间: 没有估计
难度: 简单
社区贡献指南
我们社区的一个非常棒的成员制作了本指南。它不是由 iFixit 工作人员创建的。
This guide explains how to safely test a capacitor using a digital multimeter. It focuses on practical, workshop-ready methods that technicians, repair professionals, and electronics hobbyists can use to determine whether a capacitor is functioning properly or needs replacement.
      • Digital multimeter with capacitance and resistance modes
      • Insulated test leads or alligator clips
      • Discharge resistor (15 kΩ–50 kΩ, appropriate wattage)
      询问修复机器人
      添加评论
      • Capacitors can retain electrical charge even after power is disconnected.
      • Always discharge a capacitor before handling or testing it.
      • Failure to do so can result in electric shock, damage to the multimeter, or injury.
      • Never short a capacitor directly with a screwdriver, as this may cause sparks, arcing, or component damage.
      询问修复机器人
      添加评论
      • Use a resistor connected across the capacitor terminals to discharge stored energy safely. Hold the resistor in place for several seconds to ensure the voltage drops to a safe level.
      • Confirm with the multimeter (DC voltage mode) that the residual voltage is close to zero before proceeding.
      询问修复机器人
      添加评论
      • For accurate measurements, remove the capacitor from the circuit board or disconnect at least one of its leads.
      • Testing a capacitor in-circuit can lead to incorrect readings due to parallel components such as resistors or inductors.
      询问修复机器人
      添加评论
    1. How to Test a Capacitor with a Multimeter, Measure Capacitance with a Multimeter: 步骤 5 中的图像 1,1
      • Most modern digital multimeters include a dedicated capacitance mode, typically marked with a capacitor symbol.Set the multimeter to capacitance mode.
      • Connect the red probe to the positive terminal and the black probe to the negative terminal (for polarized capacitors). Wait for the reading to stabilize on the display.
      • Compare the measured value to the capacitance rating printed on the capacitor body. In general, a capacitor is considered acceptable if the measured value is within ±10–20% of its rated capacitance. Values significantly lower than the rating usually indicate degradation or failure.
      询问修复机器人
      添加评论
    2. How to Test a Capacitor with a Multimeter, Test Using Resistance (Ohm) Mode: 步骤 6 中的图像 1,1
      • If your multimeter doesn't support capacitance measurement, resistance mode can still provide useful information. You can set the multimeter to a medium resistance range (e.g., 1 kΩ or 10 kΩ). Then connect the probes to the two terminals of the capacitor and observe the changes on the display.
      • A normal capacitor will initially show a low resistance value, which then gradually increases to a very high resistance value as it charges. If the reading remains close to zero, the capacitor is short-circuited. If the reading always shows infinity and doesn't change, the capacitor may be open-circuited and damaged.
      询问修复机器人
      添加评论
      • Another simple method is to check if the capacitor can retain its charge. We briefly charge the capacitor using a low-voltage DC power supply below its rated voltage. After disconnecting the power, set the multimeter to DC voltage mode and measure the voltage across the capacitor.
      • If the capacitor retains a voltage close to the applied voltage (briefly), it is likely working correctly. If the voltage immediately drops to zero, the capacitor may be faulty.
      询问修复机器人
      添加评论
结论
A multimeter with capacitance mode provides the most direct and reliable results, while resistance and voltage-based methods can serve as practical alternatives.For a more detailed explanation of capacitor behavior, safety standards, and advanced testing methods, see this in-depth guide:
How to Test a Capacitor with a Multimeter – Detailed Guide
取消:我没有完成这个指南。
3等其他人完成本指南。
作者
与
Colin
于12/25/25注册
449 声望
创作了3篇指南
1指南评论
excelentes dicas,ajuda muito.
J.L.A. - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 94
过去 7 天: 632
过去 30 天: 2,382
总计 5,385
