跳转到主内容
How to Tailor Your Pants
你所需要的
  1. How to Tailor Your Pants, How to Tailor Your Pants: 步骤 1 中的图像 1,1
    • To make the process of tailoring your pants easier, use a second pair of pants that already has the desired length as an outline.
    • Place the pants with the length you want on top of the pants that you will be tailoring.
  2. How to Tailor Your Pants: 步骤 2 中的图像 1,1
    • Measure the length you want to cut off with your fingers.
    • The amount of fingers you use may vary depending on the length you want to cut off.
  3. How to Tailor Your Pants: 步骤 3 中的图像 1,1
    • Pin your pants at the length you want to cut off.
    • An alternative option to pinning your pants is marking the length with a pencil.
  4. How to Tailor Your Pants: 步骤 4 中的图像 1,1
    • Cut along the pins.
    • Cut along the pencil mark if you chose this option instead.
  5. How to Tailor Your Pants: 步骤 5 中的图像 1,1
    • Fold the pants so that the seam is on the inside. Next, sew along the folded edge with a sewing machine.
    • Pin the pants to keep the fold in place and to make sewing easier.
  6. How to Tailor Your Pants: 步骤 6 中的图像 1,1
    • Check to make sure your pants are now your desired length.
  7. How to Tailor Your Pants: 步骤 7 中的图像 1,1
    • If you have achieved your desired length then you are finished!
结论
You finally finished sewing your jeans so now you can enjoy wearing them :)
Exlexis Archouletta
于10/20/20注册
133 声望
撰写一个指南
团队
CSU Los Angeles, Team S12-G14, Harris Fall 2020 CSU Los Angeles, Team S12-G14, Harris Fall 2020 的会员
CSULA-HARRIS-F20S12G14
1 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 26
总计 607
