跳转到主内容
How to Switch the Door Swing
你所需要的
  1. How to Switch the Door Swing, Unfasten the door: 步骤 1 中的图像 1,1
    • Use a T25 Torx driver to remove the four 15.4 mm‑long screws holding the door hinge to the front panel.
  2. How to Switch the Door Swing, Remove the door: 步骤 2 中的图像 1,1
    • Slide the door hinge plate up and remove the door.
  3. How to Switch the Door Swing, Unfasten the strike: 步骤 3 中的图像 1,1
    • Use a T25 Torx driver to remove the six 15.4 mm‑long screws securing the strike.
  4. How to Switch the Door Swing, Remove the strike: 步骤 4 中的图像 1,3 How to Switch the Door Swing, Remove the strike: 步骤 4 中的图像 2,3 How to Switch the Door Swing, Remove the strike: 步骤 4 中的图像 3,3
    • Slide the strike up and toward you to remove it.
  5. How to Switch the Door Swing, Unfasten the inner door face: 步骤 5 中的图像 1,1
    • Lay the door face down on a towel or blanket before continuing to prevent any damage to the finish.
    • Use a Phillips #2 driver to remove the ten 17.6 mm‑long screws securing the inner door face.
  6. How to Switch the Door Swing, Remove the inner door face: 步骤 6 中的图像 1,3 How to Switch the Door Swing, Remove the inner door face: 步骤 6 中的图像 2,3 How to Switch the Door Swing, Remove the inner door face: 步骤 6 中的图像 3,3
    • Be careful performing this step, as the door glass will be also be lifted. It will be heavy and awkward.
    • Lift the inner door face off the door frame.
  7. How to Switch the Door Swing, Unfasten the hinge: 步骤 7 中的图像 1,1
    • Use a T25 Torx driver to remove the five 15.4 mm‑long screws securing the hinge.
  8. How to Switch the Door Swing, Remove the hinge: 步骤 8 中的图像 1,3 How to Switch the Door Swing, Remove the hinge: 步骤 8 中的图像 2,3 How to Switch the Door Swing, Remove the hinge: 步骤 8 中的图像 3,3
    • Slide the hinge out of its slot in the door and remove it.
    • You may find it easier to remove the hinge with it propped up, as the whole assembly is cumbersome to hold.
  9. How to Switch the Door Swing, Unfasten the catch: 步骤 9 中的图像 1,3 How to Switch the Door Swing, Unfasten the catch: 步骤 9 中的图像 2,3 How to Switch the Door Swing, Unfasten the catch: 步骤 9 中的图像 3,3
    • Lay the door face down before continuing.
    • Use a T25 Torx driver to remove the three 15.4 mm‑long screws securing the catch plate and cover.
    • Remove the catch cover. The catch plate will fall off and rest inside the door frame.
  10. How to Switch the Door Swing, Remove the catch plate: 步骤 10 中的图像 1,2 How to Switch the Door Swing, Remove the catch plate: 步骤 10 中的图像 2,2
    • Slide the catch cover off the door and remove it.
    • The catch plate will fall off and rest inside the door frame.
  11. How to Switch the Door Swing, Remove the catch plate: 步骤 11 中的图像 1,2 How to Switch the Door Swing, Remove the catch plate: 步骤 11 中的图像 2,2
    • While lifting up the door face, remove the catch plate.
    • Set it aside with the catch plate cover. You'll use it during reassembly.
  12. How to Switch the Door Swing, Replace the hinge: 步骤 12 中的图像 1,3 How to Switch the Door Swing, Replace the hinge: 步骤 12 中的图像 2,3 How to Switch the Door Swing, Replace the hinge: 步骤 12 中的图像 3,3
    • Place the hinge into the position where you just removed the catch plate and catch cover.
    • The rounded rectangular boss will help you align the hinge.
    • Use a T25 Torx driver to replace the five 15.4 mm‑long screws securing the hinge.
  13. How to Switch the Door Swing, Replace the catch plate: 步骤 13 中的图像 1,2 How to Switch the Door Swing, Replace the catch plate: 步骤 13 中的图像 2,2
    • With the inner door face lying flat on top of the door frame, lift the edge of the face where the hinge used to be.
    • Position the catch plate so that the boss on the catch plate will go through the rounded rectangular hole.
    • Replace the catch plate.
  14. How to Switch the Door Swing, Replace the catch plate cover: 步骤 14 中的图像 1,3 How to Switch the Door Swing, Replace the catch plate cover: 步骤 14 中的图像 2,3 How to Switch the Door Swing, Replace the catch plate cover: 步骤 14 中的图像 3,3
    • Take the catch plate cover with the three screws already in position and place it down over the catch location.
    • Use a T25 Torx driver to replace the three 15.4 mm‑long screws securing the catch plate and cover.
    • You may need to lift the inner door face and the catch plate together to allow the screws to thread into the catch plate.
  15. How to Switch the Door Swing, Replace the inner door face: 步骤 15 中的图像 1,1
  16. How to Switch the Door Swing, Replace the strike: 步骤 16 中的图像 1,3 How to Switch the Door Swing, Replace the strike: 步骤 16 中的图像 2,3 How to Switch the Door Swing, Replace the strike: 步骤 16 中的图像 3,3
    • Slide the strike into the slot on the chassis across from its original location.
  17. How to Switch the Door Swing: 步骤 17 中的图像 1,1
    • Use a T25 Torx driver to replace the six 15.4 mm‑long screws securing the strike.
  18. How to Switch the Door Swing, Re-install the door: 步骤 18 中的图像 1,3 How to Switch the Door Swing, Re-install the door: 步骤 18 中的图像 2,3 How to Switch the Door Swing, Re-install the door: 步骤 18 中的图像 3,3
    • Position the door so that the hinge plate engages the slots in the chassis.
    • The door will stay in place without the screws when properly installed.
    • Use a T25 Torx driver to replace the four 15.4 mm‑long screws holding the door hinge to the front panel.
    • You're done and ready to start swinging!
结论
Repair didn’t go as planned? Ask our Answers community for help.
Bill Gilbert
于06/30/22注册
38,516 声望
创作了261篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,743篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 9
总计 193
