跳转到主内容
How to Strip and Recoat a Cast Iron Skillet
你所需要的
  1. How to Strip and Recoat a Cast Iron Skillet, How to Replace a Cast Iron Skillet Coating: 步骤 1 中的图像 1,3 How to Strip and Recoat a Cast Iron Skillet, How to Replace a Cast Iron Skillet Coating: 步骤 1 中的图像 2,3 How to Strip and Recoat a Cast Iron Skillet, How to Replace a Cast Iron Skillet Coating: 步骤 1 中的图像 3,3
    • Clamp down opposite sides of the cast iron skillet to a table.
    • Make sure the clamps are secure to avoid injury.
  2. How to Strip and Recoat a Cast Iron Skillet: 步骤 2 中的图像 1,3 How to Strip and Recoat a Cast Iron Skillet: 步骤 2 中的图像 2,3 How to Strip and Recoat a Cast Iron Skillet: 步骤 2 中的图像 3,3
    • Grind off the black coating of the entire surface to expose the shiny bare metal.
    • Make sure to have on all your safety equipment for this process.
  3. How to Strip and Recoat a Cast Iron Skillet: 步骤 3 中的图像 1,3 How to Strip and Recoat a Cast Iron Skillet: 步骤 3 中的图像 2,3 How to Strip and Recoat a Cast Iron Skillet: 步骤 3 中的图像 3,3
    • Sand the entire surface of the cast iron skillet to smooth any rough spots left.
  4. How to Strip and Recoat a Cast Iron Skillet: 步骤 4 中的图像 1,2 How to Strip and Recoat a Cast Iron Skillet: 步骤 4 中的图像 2,2
    • Rinse the cast iron skillet with water.
    • Scrub the cast iron skillet with a sponge to remove any excess metal shavings.
  5. How to Strip and Recoat a Cast Iron Skillet: 步骤 5 中的图像 1,2 How to Strip and Recoat a Cast Iron Skillet: 步骤 5 中的图像 2,2
    • Apply an even coating of high heat oil to every part of your cast iron skillet.
  6. How to Strip and Recoat a Cast Iron Skillet: 步骤 6 中的图像 1,2 How to Strip and Recoat a Cast Iron Skillet: 步骤 6 中的图像 2,2
    • Wrap the bottom rack of the oven with aluminum foil.
    • Place the cast iron skillet upside down on the rack above the foil.
    • Bake for 1 hour in a preheated oven of 500°F (260°C) or whatever the highest temperature your oven reaches.
    • Let the cast iron skillet cool completely after baking.
  7. How to Strip and Recoat a Cast Iron Skillet: 步骤 7 中的图像 1,3 How to Strip and Recoat a Cast Iron Skillet: 步骤 7 中的图像 2,3 How to Strip and Recoat a Cast Iron Skillet: 步骤 7 中的图像 3,3
    • Repeat steps 5 and 6 until a dark black coating has formed.
结论
The finished product will be a dark black that resembles a non-stick coating and has no sticky patches.
3等其他人完成本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 12
过去 30 天: 61
总计 4,182
