简介
When individuals purchase formal shirts, they may find that the length of the shirt does not fit their body accurately. This guide will display the process of altering and sewing formal shirts for better fit.
你所需要的
Pick the shirt that requires alterations, then select a different shirt has your desired fit and measurements.
Place the shirt that currently fits you on top of the shirt that is meant to be shortened.
Stitch on the regular setting of your sewing machine.
Set your range between 4 mm or up to 6 mm for your stitching.
On that stitching pattern, select the straight stitch on the sewing machine dial, or any alternative controls available (stitch selector should be 6 or 7).
The stitch tension should be 4.
2等其他人完成本指南。
