跳转到主内容
How to Shorten a Belt
你所需要的
  1. How to Shorten a Belt, Measure the Belt: 步骤 1 中的图像 1,1
    • Put your belt on.
    • Using a ruler or measuring tape, measure how much of the belt you want to remove. Make this mark on the buckle end of the belt.
    • Place a mark where you will cut the belt to shorten it.
  2. How to Shorten a Belt: 步骤 2 中的图像 1,2 How to Shorten a Belt: 步骤 2 中的图像 2,2
    • Measure how much of the belt is folded over the belt. Add that length to the cut mark to leave enough material to fold over the buckle.
    • Using a screwdriver, remove all screws from the buckle end of the belt.
  3. How to Shorten a Belt: 步骤 3 中的图像 1,1
    • Using scissors, cut on the exact spot of your new mark.
    • You can round the edges of the cut to make the belt tip look neat.
    • You can add shoe or leather polish to the cut mark to ensure it is the same color as the belt.
  4. How to Shorten a Belt, Reassembling the Belt: 步骤 4 中的图像 1,3 How to Shorten a Belt, Reassembling the Belt: 步骤 4 中的图像 2,3 How to Shorten a Belt, Reassembling the Belt: 步骤 4 中的图像 3,3
    • Reinsert the screws and screw them back in place using a screwdriver.
  5. How to Shorten a Belt, Add New Buckle Holes to the Belt: 步骤 5 中的图像 1,2 How to Shorten a Belt, Add New Buckle Holes to the Belt: 步骤 5 中的图像 2,2
    • Place your belt on a workspace that can be nailed into.
    • Place a nail on the new spot where you'd like to add a hole.
    • Hammer the nail until it goes all the way through the belt.
    • Caution: Be careful when using a hammer.
  6. How to Shorten a Belt: 步骤 6 中的图像 1,2 How to Shorten a Belt: 步骤 6 中的图像 2,2
    • Try on the belt and see if it fits comfortably.
    • If not, follow this guide again to add more holes.
终点
另外一个人完成了本指南。
Uvaldo Chan
于04/12/21注册
154 声望
撰写一个指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 73
总计 2,862
