跳转到主内容
How to Sharpen a Dull Chisel
你所需要的
  1. How to Sharpen a Dull Chisel, How to Sharpen a Dull Chisel: 步骤 1 中的图像 1,1
    • Use water or a mild cleaning solution with a rag or sponge to remove any grime or dirt from the chisel.
    • This helps expose any rust or damage and prevents debris from interfering with sharpening later.
  2. How to Sharpen a Dull Chisel: 步骤 2 中的图像 1,1
    • Next apply WD40 lubricant around any rusted areas before moving on to the next step.
    • Scraping dry rust can damage the metal and make the process unnecessarily difficult.
  3. How to Sharpen a Dull Chisel: 步骤 3 中的图像 1,1
    • Use a brass wire brush to scrub the rusted areas.
    • Focus especially on the blade and any areas that will contact the sharpening stone.
    • Use caution with the wire brush, as its sharp bristles can cause injury.
  4. How to Sharpen a Dull Chisel: 步骤 4 中的图像 1,1
    • Use a clean rag to remove any leftover WD-40 or rust residue.
    • This is important — if oil stays on the blade, it can make your sharpening stone less effective by repelling water.
  5. How to Sharpen a Dull Chisel: 步骤 5 中的图像 1,2 How to Sharpen a Dull Chisel: 步骤 5 中的图像 2,2
    • Soak the wet sharpening stone with water for a couple of minutes and place it on a flat surface.
    • Hold the chisel at a 20-degree angle and push it forward against the stone to grind the edge. After each stroke, lift the chisel and return it to the starting position.
    • Repeat this motion on both sides of the stone until the chisel reaches your desired sharpness.
    • Water acts as a lubricant, helping to carry away metal particles and prevent clogging during sharpening.
  6. How to Sharpen a Dull Chisel: 步骤 6 中的图像 1,2 How to Sharpen a Dull Chisel: 步骤 6 中的图像 2,2
    • With a rag, carefully wipe of any debris and metal shaving possible left on the chisel.
    • Apply a small amount of WD-40 to protect the metal from rust.
    • Keep in mind that this is only a temporary measure.
    • Use caution—this blade is now significantly sharper.
结论
After you follow all these steps, you should have a nice, clean chisel
另外一个人完成了本指南。
Christine Vu
于03/04/25注册
142 声望
撰写一个指南
团队
CSU Los Angeles, Team 3-10, Grodsky Spring 2025 CSU Los Angeles, Team 3-10, Grodsky Spring 2025 的会员
CSULA-GRODSKY-S25S3G10
2 名成员
创作了2篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 12
总计 132
